#11 | |
Liked 54 Times in 24 Posts
Todd Gross 3323 FS/E,F |
#12 |
I just went thru this on my drag pak with 16 volt battery
I thought my controllers was burnt up from the hi voltage and purchased new modules Come to find out the controllers in my car where good and just didn’t like the high voltage Friend at golf cart shop got me a voltage step down that they use on the carts to install radios n lights For 15 bucks the voltage step down box worked Bob |
#13 |
I tried a few different things.most did not reduce voltage to where the controller was happy.ended up with a reducer from red hawk #volt0009.works good with car running,not so much when its not.the only thing good about these door glass controllers is they tell you when your battery is low.
Scott justo. 2009018 lc22r |
#14 |
Liked 1,345 Times in 410 Posts
Well some of my questions were answered. I just started building a 2009 Challenger for stock this last couple weeks. Took that long to strip a real street car. One old guy anyway. The windows are a problem. I'm reading here that the Drag pak Door Modules are not available anymore. I'm not that sharp on what it takes to wire it. I've stripped the interior and removed the dash assembly to get ready for a roll cage. Amazingly enough though the wiring is out of the car from the dash forward. The mirrors still operate and the doors lock. Have no clue how to fix the windows yet. Any help would be great.
Paul Haszlauer |
#15 |
Liked 8 Times in 5 Posts
Paul,
I can help you out on the wiring and some other unique Drag Pak components. PM me when you have time. John
John Donato Stk / SS 3435 |
#16 |
Thanks John,
Hopefully I sent you the P.M. correctly |
#17 |
Liked 10,769 Times in 2,238 Posts
John helped me fix mine. Thanks again John!
#18 |
Liked 44 Times in 13 Posts
John is the man on the DP Challenger.....
Mack Reeves 2377 STOCK & SUPER STOCK |
