Old 06-27-2019, 07:49 PM   #1
Casey Miles
Liked 508 Times in 92 Posts
Default Buyer Be Awhere
I purchased a new set of Richmond 5:86 Pro gears. When I went to install them, I found that the yoke of the driveshaft wouldn't fit like it did on the Richmond gears coming out of the car. I struggled to make it fit, but I got it to sort of fit with hitting it with a mallet. It gets better! The small bearing in the rear is supposed to no slop float. When I tried to get the pinion in the rear, it sort of got pressed in. It took me over a half hour of banging on the pinion to get it out of the housing. So I put a caliper on it to find that the pinion was .002 bigger bearing surface of the gear that came out. I called Richmond gear and they told me that it was in tolerance and that I should emery cloth it to fit. I have had at least 15 sets of Richmond gears and never had a problem, these gears were manufactured in Italy. The rep at Richmond said that they can't do anything for me. Not happy with Richmond at all!!!
So, if you have a spare set of gears from Richmond in your trailer in case you have breakage, you better check to see if they are the correct measurements. I'm taking the pinion to a machine shop to get it cut, at the track you're done!
Casey Miles
248H Stock
Old 06-28-2019, 09:30 AM   #2
Steve Stasko
Liked 286 Times in 146 Posts
Default Re: Buyer Be Awhere
Richmond hasn't been Richmond for a few years now. That Richmond is a Motive Gear in a Richmond box. I bought a Motive D-60 Pro Gear for my car, didn't have any issues with the installation...but the spares on my shelf are neither Motive or Richmond...
Old 06-28-2019, 09:40 AM   #3
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
US gear. I used to be lucky to get 100 runs on Charlene's car and mine with the Richmond gear. Switched to US gear and have over 200 on mine and are still quiet.
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 06-28-2019, 10:17 AM   #4
John Dinkel
Liked 263 Times in 68 Posts
Put it in a lathe and use sand paper to get it to the size you want
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 06-28-2019, 11:07 AM   #5
Casey Miles
John, I understand what you’re saying, but I purchased a product at a premium price and it should fit without any modifications like a premium product. If I were at the track with a broken ring and pinion, I’d be screwed.
Does US Gear make 5:86 for a 12 bolt, if so, I’ll never buy a Richmond gear set ever again!
Casey Miles
248H Stock
Old 06-28-2019, 11:21 AM   #6
Dave Sheehan
Casey Miles
248H Stock
https://www.summitracing.com/parts/ugr-01-988586
F/SA W228
Dave Sheehan is offline   Reply With Quote
Old 06-28-2019, 11:23 AM   #7
Bob Gullett
https://proshop.summitracing.com/int...8586/overview/
68 Chevy11 327 F/S
Old 06-28-2019, 12:06 PM   #8
rawhide
Liked 7 Times in 5 Posts
US Gear must be pretty good stuff as a couple of weeks ago Ford Performance released a 8.8" 3.73 gear that is made by them. It cost more that the Sterling gears do.
Roland
rawhide is offline   Reply With Quote
Old 06-28-2019, 01:03 PM   #9
Brian Oakes
Liked 436 Times in 116 Posts
Casey, ya normally do the put it in a lathe, anyway, i have a set of 586's out of my SS car
maybe 75 runs on the,these are micronited already, it cost 400 alone to have these done $400.00 plus the ride. i will never use them again.
Brian Oakes is offline   Reply With Quote
