#81 |
Liked 11 Times in 4 Posts
"Haters and Drama" Jeff did you ever think that you create that? I raced Cody heads up a few years ago in Vegas . I noticed your weight sticker after we flipped the coin. 2780 lbs the class min in ss/bs is 2850lbs I talked too Cody and said he needs too add 70 lbs too get too class minimum. I talked too you and you told Cody too pull the car up. I told you then you dont want too do that. You guys did and 25 minutes later Cody was tossed. In the Dragster a while later I read it was a 'misunderstanding". I dont beleive that is a misunderstanding. I told you what was going too happen before we raced. Thats my 2 cents Put it towards a Rule book or a mirror. Grant Singer
#82 |
Liked 4 Times in 3 Posts
What is the actual rule for a DQ'd run after you already made a good run and you are on the Ladder?
#83 |
Liked 527 Times in 86 Posts
If it’s only a situation where you legitimately came up 10 lbs light on the scales, that run does not count but you are still on the sheet. If it’s a different violation, like fuel, you may be dq’d from the race if you can’t pass fuel check. If it’s something illegal found by tech, you are dq’d from the event, well you should be, and suspended (again, should be).
#84 |
We, the honest class racers, need to band together and MNHRAGA!!!!!
#85 |
Liked 7,745 Times in 1,740 Posts
Looks like a money-making bumper sticker AND hat to me!
#86 |
Liked 534 Times in 143 Posts
#87 |
I'll take two t-shirts (XXL) and a skull cap - MNHRAGA
#88 |
Looks like an opportunity here for Butner to make some shirts. Bryan maybe you can get some royalties.
#89 | |
Liked 1,032 Times in 368 Posts
MNHRAGA Locals 1-2-3-4-5-6-and 7
Jeff Niceswanger 3740 SS |
