Liked 302 Times in 73 Posts
Does this still need to be a bolt in unit? I don't see it specifically addressed in the rulebook like I thought it used to be. Unless they are just considering it a "Traction bar." Just thought previous versions specifically called out Anti Roll.
Maybe I'm crazy Brad |
#2 | |
Liked 370 Times in 101 Posts
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
Liked 7,768 Times in 1,741 Posts
Under Traction Bars, third sentence, "bolt on traction DEVICES permitted".
Liked 883 Times in 237 Posts
Billy is correct .
Although some have argued that the anti-roll bar is not a traction device , NHRA correctly sees it as such.
Just another interesting (and ignored) Rule Book note,under Traction Bars, sentence4, "device must be installed under leaf spring" which would mean that cal-tracs would not be legal as a portion of the "device" is installed above the leaf spring. Go figure.
Liked 920 Times in 259 Posts
I prefer for it to be bolt in/removable in some fashion since it is a wear item that is subject to occasional cleaning/lube/maintenance. Easier to get the assembly out of the car to work on it.
#9 | |
I'm going to guess this slides by because it mounts in the original hole the leaf spring mounted in so it's not technically mounting "above" even though the Cal-tracs does lower the mounting hole of the spring itself once installed so it is physically above once installed. |
