Old 08-01-2019, 08:08 PM   #1
Default Digitizing Cylinder Heads Help
Guys I need some help on understanding digitizing cylinder heads. I know this should be in the tech section, but I would like to get as many opinions as possible to understanding how this process works. Can the complete head be digitized. Meaning ports, bowl area, combustion chambers, every little nook and cranny so to speak.
Old 08-01-2019, 08:28 PM   #2
Greenlight
Liked 79 Times in 22 Posts
Default Re: Digitizing Cylinder Heads Help
You can digitize anywhere the probe (usually 3mm dia.) can get to.
Take a look at this.
Greenlight is offline   Reply With Quote
Old 08-01-2019, 09:02 PM   #3
Ken,
Yes, the ports and chambers can be fully digitized.
Old 08-01-2019, 10:28 PM   #4
SSDiv6
The are probe digitizers, laser digitizers and 3D scanners.
Yes, you can digitize and reverse engineer a cylinder head and even more complex parts.
Old 08-01-2019, 11:51 PM   #5
Interesting video, but that looks like a lengthy process, and it does not show how far then can go. So there are 3 types of scanners, they have to be very expensive. Can a laser scanner digitize around bends like a short turn radius. It looks like the technology is here, but how good is it really. I guess I'm not sold on it yet. Time do more research, thanks guys.
Old 08-02-2019, 01:06 AM   #6
novassdude
Liked 136 Times in 49 Posts
The technology has been there for quite some time to digitize cylinder heads. If NHRA could get together with the manufactures they could really find out who's heads have been massaged. Not that there are any ported heads in stock.
novassdude is offline   Reply With Quote
Old 08-02-2019, 08:02 AM   #7
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Talking Re: Digitizing Cylinder Heads Help
Now that is really funny to read first thing in the morning !
Old 08-02-2019, 02:40 PM   #8
SSDiv6
Yes, 3D laser scanner or a Renishaw Cyclone digitizer can digitize around bends, contours, radiuses and more.
Old 08-04-2019, 08:58 AM   #9
Andy Friar
Andy Friar's Avatar
Liked 226 Times in 76 Posts
Ken I understand being skeptical of the technology, but it really is that accurate these days. Most high end CNC machines these days have CMM probes on 3,4 or 5 axes arms inside the machine that do spot quality check's to .0005" accuracy, and then per an algorithm adjust tool paths for cutter wear, ambient temp and humidity differences, etc. Being a reporter, maybe you could drum up interest from a laser scanner/ CMM company to do an in depth 'how it works' article. What head are you specifically looking to scan? I ask because a lot of late model parts are available from the OEM via Sema: https://www.semagarage.com/techtransfer/Index
Some of the late model head CNC porting shops might have the base OEM CAD and/or full combustion, intake, exhaust port scanning capabilities too. It is isn't cheap, but the most accurate way, by far, to analyze the CFD flow in and out of the engine. Interesting stuff, gonna follow this thread...
Andy Friar
Last edited by Andy Friar; 08-04-2019 at 09:00 AM. Reason: missing words, too many dumb words. Need more coffee...
Andy Friar is offline   Reply With Quote
Old 08-06-2019, 05:06 PM   #10
Lynn A McCarty
Lynn A McCarty's Avatar
Our people say they can get to 99% accuracy from a port, however, when going to the seat area, there are metrics like "picking the throat size." In this case we chose to go 92% that reduced flow quite significantly, so be very careful. We are doing a 642 cubic inch Pontiac engine and the throat size is the limiting factor. We brought the flow back with a carefully constructed intake manifold runner by Mr RPM himself, "the Kat" Rick Katterjohn.
Lynn McCarty
www.ramairv.com
317.260.3486
Name:	winle intake test.jpg
ID:	50915   Click image for larger version
Name:	intake runner.jpg
Lynn A McCarty 3470 SS
Lynn A McCarty is offline   Reply With Quote
