Old 08-10-2019, 11:54 AM   #11
cyclonebfx
Liked 5 Times in 2 Posts
Default Re: 12V racing battery recommendations
I used to run the optima batteries because they would last forever but they weigh a ton! Recently switched to the Odyssey batteries and have been really happy so far.
5705 F/S
5706 D/SA
cyclonebfx is online now   Reply With Quote
Old 08-10-2019, 07:03 PM   #12
rboyle
rboyle's Avatar
Liked 599 Times in 165 Posts
Check out AntiGravity's line of batteries.
I found out about them from some off road friends and they are really rugged and dependable.
And they are extremely light weight.
A couple of my customers have switched to them with great results. https://shop.antigravitybatteries.co...extreme-power/
I ordered the Antigravity! Thank you Tom!
Old 08-11-2019, 07:59 AM   #13
Glenn Briglio
Glenn Briglio's Avatar
Liked 976 Times in 311 Posts
Which one did you go with?
Old 08-11-2019, 11:06 AM   #14
rboyle
rboyle's Avatar
https://shop.antigravitybatteries.co...me-power/v-10/
Hi Glen. The xtreme power 10 cell.
Old 08-11-2019, 11:55 PM   #15
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Originally Posted by Troy Henderson View Post
I actually just posted about this topic on my FB page. I replaced my Optima with a Big Crank ETX30L AGM this season. Weight is 24 lbs and is half the price of a Braille B3121.
https://www.batterymart.com/p-Big-Cr...qWOStM0Zl4z-xU
I received an email for 8% off if you enter "8offaug" this month.
Interesting. This is the battery I use in my PWC. Does it have enough power to run the fan and water pump for a decent amount of time?
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 08-12-2019, 09:58 AM   #16
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
I think you will be happy with it .
Just be sure to follow the charging instructions.
Like any battery ,proper charging rate and voltages are key to longevity.
Old 08-15-2019, 04:49 PM   #17
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
I have used two 11.5 lbs Braille battery's for years in the six pack car with zero let downs. Once the starter acted a little slow, battery was ok just a loose cable. My alternator works. I have tested and could go three rounds without charging in between rounds. I did cool car with sprayer until temp was reached then turn off fan. I change them out every three years.
Sounds like you and I have exactly the same battery experience, Larry. This is the 4th season on my two 11.5 lb Braille batteries. I even completely killed them once last year by leaving the water pump on for 5 hours...discovered this fact when they called us up for first round. Charged them for 15 minutes or so, the car started, and I still beat a few people to the lanes.
Paul Merolla is offline   Reply With Quote
Old 08-16-2019, 10:43 AM   #18
btrc
Liked 84 Times in 42 Posts
A few years ago my car wouldn't start for the semi finals at a race and I decided that this was not going to happen again.
Now between rounds I run the fan and water pump from the (2) deep cycle batteries in the trailer normally for the winch and jack. I run 4 ga cables to a switch box and then 4 way cable to a 4 pole plug. The 4 way socket in the car is wired in parallel to the normal wires.
Bob Tilton
568 FS/H
btrc is offline   Reply With Quote
Old 08-16-2019, 08:52 PM   #19
cmracing
Liked 62 Times in 29 Posts
Made 13 passes Saturday with a single Group 31 in the trunk, 105amp GM alternator supplying the juice, never had my charger out. Doubt there are many cars using as much power as mine:
Dual stock GM F-Body fans, over 20 amps each.
Mezier electric water pump.
Weldon EFI fuel pump.
8 injectors, though they take very little.
4 coil packs (DIS waste fire setup, like a GN).
The last two hours ran the electric fan on the 2nd trans cooler, not sure what it draws.
The last 6 passes were made 15 minutes between each, only got to the trailer for fuel.
So....... Why mess with these little batteries you have to worry about charging when there are massive batteries out there that will never give you an issue?
cmracing is offline   Reply With Quote
Old 08-17-2019, 03:23 AM   #20
GTX JOHN
Liked 2,494 Times in 701 Posts
I run one or two Walmart budget batteries (either 26 or 56 as I recall)
that weigh 26 Lbs. I have been for 25 years. Easy to exchange on the
road if needed. They have recently gone up to $49.95.
I do charge them in the latter rounds.
John Irving
741 Stock
741 Super Stock
GTX JOHN is online now   Reply With Quote
