#11 |
Liked 31 Times in 12 Posts
Warren,
Thank you for the wonderful telecasting of the races. The bosses don't say much when I have it on my second monitor down low at work :-) |
#12 |
Liked 175 Times in 78 Posts
You didn't really expect NHRA.TV to bend with the schedule change - did you?
I did not but I am up at 4:30am just in case. Ron
time is our most precious resource, you can always make more money but you can never make more time spend your time wisely with the ones you love - Ron Durham |
#13 |
Liked 128 Times in 32 Posts
Warren
The stream is working pretty good again today, the audio is different, it almost sounds like the microphones down track are softer, and maybe past the finish line? I can hear the sound of sticky slicks rolling, engines off, and rear gears making the coasting noise. Its not distorted downtrack now, but not as much engine sounds. I like the sound of a good stick car crashing the gear box, and coming at the microphone, and that is mostly absent now. Maybe that audio part is not your doing? I know its tough to get the volume level correct on that one. I would like to see you switch back to the behind the line camera. I have always hated the camera between the lanes, pointed at the tree. I have always preferred a side or rear view. Your camera mounted on the crossover bridge (like during class) was much better in my opinion. I liked watching all the crew guys doing their thing, and its a better view of the cars going straight, and who is doing a good job lining up drivers in the groove. I was calling which cars were about to launch crossed up! With the wide angle, tree facing ground camera, it provides none of the good stuff. If I were Fox, I would drop that camera all together! It seems like its just good for the chevy billboard? I really like the run numbers recap of the timing, driver name, dial in, RT, etc... its perfect! Last edited by Don Sofranko; 09-01-2019 at 05:31 PM. |
#14 |
Liked 3,184 Times in 973 Posts
As expected NHRAtv is showing a 11:00 start even though Stock is scheduled to roll out at 7:30. If in fact they don’t start with the sportsman’s classes I’m going to contest the charge on my credit card for not providing coverage as advertised.
Also, since they don’t show the Norwalk show as an upcoming event does that coverage revert back to a Warren provided event? Which is fine if it does BTW.
#15 |
Liked 231 Times in 107 Posts
Yep, I was told coverage of ALL. 7:30 and no coverage. What's up with that? Jumped the gun. Good work NHRA.TV
#16 |
Liked 263 Times in 68 Posts
Racing going on but no nhra.tv
John Dinkel 3295 STK |
#17 |
Liked 22 Times in 14 Posts
#18 | |
Also , video jumped during the launch on several pair.. Just my set up , ...anyone?
#19 |
Liked 544 Times in 213 Posts
It did not work here until part way thru Stock this morning....
I am watching it live for the first time this year. Watching it on a buddies dime.....and its been working fine after being jittery earlier.... Its dark,dank and has been raining here in New Jersey. Can't go outside so might as well watch todays race.... Indy weather looks to be improving and should be good the rest of the day....
#20 |
Liked 1,569 Times in 189 Posts
FYI for all - The regular crew came in on Friday and took over the operation. I helped a bit with the production on Friday but was released for the rest of the weekend and came home yesterday. The Norwalk coverage will be my usual setup, but only available on NHRA.tv. I'll be back to dragracer.tv coverage on Saturday from Earlville, IA.
