Old 09-03-2019, 07:40 PM   #1
e vassar
Liked 271 Times in 107 Posts
Default Shutting off engine crossing finish line
Ive noticed a few people doing this.
What's the reason?
Old 09-03-2019, 07:48 PM   #2
TOSTO RACING
TOSTO RACING's Avatar
Liked 652 Times in 184 Posts
Default Re: Shutting off engine crossing finish line
Save parts, easier on valve springs.
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is offline   Reply With Quote
Old 09-03-2019, 07:59 PM   #3
HR9121
HR9121's Avatar
On those runs that you may be using a minimal amount of oil in the pan it's a good idea so if the oil runs away from the pickup when you're in the shutdown area.
James Williamson
W200 J/SA. SS/JA
Old 09-03-2019, 08:02 PM   #4
jmcarter
jmcarter's Avatar
Liked 3,205 Times in 977 Posts
Vastly easier and safer if you have a clean neutral of course
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 09-03-2019, 08:20 PM   #5
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Noticed this practice a lot while standing just passed the finish line during SS @ the US Natls, this weekend.
Old 09-03-2019, 08:26 PM   #6
Jared Jordan
Liked 540 Times in 120 Posts
Send a message via AIM to Jared Jordan
Not as hard on parts, in general, but it does depend on the car.
The '65 SS/BA Belvedere I drove once upon a time would tear up rod bearings if I didn't go into neutral past the finish line. Never tied itself up because Grandpa was meticulous about maintenance; particularly the preventative type. After we went to "clean neutral" in the valve body and I could kill it at the stripe, that was never an issue again.
On the other hand, my '64 Dodge H/SA car has great oil pressure through the entirety of the shutdown area and does not have a "clean neutral." Racepak shows a line that descends in correlation to engine RPM, but no dips whatsoever.
Jared Jordan
9 B/SA
2024 Jeg's D7 All Star - Stock
Jared Jordan is offline   Reply With Quote
Old 09-03-2019, 08:34 PM   #7
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Stick car super easy done it for years
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 09-03-2019, 09:29 PM   #8
e vassar
So if I don't have a clean neutral, there's no reason to do it?
Old 09-03-2019, 09:45 PM   #9
J.R. Haddad
Liked 1,471 Times in 308 Posts
All the reasons above are why you do it, but it can be unsafe without
a clean neutral valve body. J.R.
J.R. Haddad is offline   Reply With Quote
Old 09-03-2019, 09:49 PM   #10
MR DERBY CITY
Liked 8,052 Times in 1,529 Posts
Mr. E,....if you have not experienced engine problems before, why would you want to shut your engine off now ? Many , many 3 speed trans builders Do NOT recommend this ....
