Liked 70 Times in 31 Posts
Is a 4th gen f body with the 231 V6 a good combo?
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
Liked 17 Times in 3 Posts
I have also kicked this idea around, since we still have my wife's car from High School, and its in great shape.
The biggest problem I have, is that its a bear to work on, with the engine so far under the cowl. Maybe some racers with this type can shed some light on this. |
#3 | |
Liked 687 Times in 198 Posts
just pull the radiator, and sway bar and you can stand in the engine compartment In front of the motor. (If your not too large) After you leave off the unnecessary brackets and accessories it should be fairly easy work on. Didn't even remove the hood, you need some shade when working in there. Last edited by Mike Gray; 09-16-2019 at 05:25 PM. |
Liked 5,121 Times in 1,952 Posts
Which one?
Liked 239 Times in 114 Posts
I think the 3.8L Series II engine is a good pick . Doesn't Harry Doolittle run one in his Firebird ?
3.8L Series II is what I was looking at. Thanks.
Liked 22 Times in 14 Posts
Yes , I realize that..1995 and newer..but there's more than one combo in F body cars.
http://www.classracerinfo.com/
Liked 309 Times in 88 Posts
Ronnie Temento from Louisiana has an N/SA Firebird with this combo and he has been in the 11.80's before. The car is for sale on RJ.
I see what Mark is asking about , one is rated at 185 and the other rated at 200 . It maybe that the FWD version is rated different .
