Old 10-08-2019, 02:43 PM   #1
Gene Daugherty
Liked 9 Times in 4 Posts
Default Super Stock GT class question
Is it legal to run a powerglide transmission behind an LS engine in Super Stock GT classes?
Gene Daugherty is offline   Reply With Quote
Old 10-08-2019, 07:36 PM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Super Stock GT class question
GT is based on SS unless otherwise noted. SS Trans reads Any automatic transmission same make as engine. Max of three forward gears unless the car came with more or less.
Dale Shearon
68 Mustang 6394
Old 10-08-2019, 09:12 PM   #3
Gene Daugherty
Thanks Dale
Old 10-08-2019, 10:05 PM   #4
Liked 5,125 Times in 1,953 Posts
I don't know if that's a direct quote but the trans has to match the engine, not necessarily the car, in GT.
Old 10-09-2019, 12:43 PM   #5
FireSale
FireSale's Avatar
2019 NHRA Rules
Super Stock
Section 12A
Page 5
Page 154 overall
TRANSMISSION, AUTOMATIC
"Any model transmission, same make as car, with a maximum of three forward speeds (unless OEM equipped with more than three forward speeds). O.D. gear not required, reverse permitted. Transmission case must be OEM or aftermarket OEM replica from a standard automotive application as found in the Official NHRA Stock Car Classification Guide...."
No special notes for trans in the GT section, so these rules apply.
"Make" means "Manufacturer" (Ford, GM) and "Model" means part ID (Glide, ect for GM, C4-C6 for Ford ect). Correct me if I have this wrong.
Dale Shearon
68 Mustang 6394
Old 10-09-2019, 01:37 PM   #6
nhramnl
Liked 358 Times in 83 Posts
This might be what you're saying, Mark, but I read the rule to say that ANY model transmission that is the same MAKE as the car, so long as it has no more than 3 forward speeds (unless it came with more, blah, blah, blah) is allowable. My interpretation is that as long as it is a transmission that was installed in a General Motors production vehicle, it is OK. If that is in fact what it says, a Powerglide would be "legal" behind any GM engine, in a legal SS/GT car. It does NOT suggest that a Powerglide would not be legal behind an LS engine, because they were never built with Powerglides.
Old 10-09-2019, 05:55 PM   #7
I think that's what it means too. Good question though. I had wondered about retrofitting a PG .
What I was getting at was that first of all, an automatic has to be available with the engine used. ( i.e. no 302 Z28s with automatic).
After that hurdle , it seems to be wide open except for this. An injected 305 from an 80's Camaro, in a 66 Chevy II, could use a 2, 3, or 4 speed automatic, whereas a 350/255 combo in same car would be limited to a 2 or 3 speed. The PG would be grandfathered in, in this example.
Nobody uses a 200 4R in class racing that I know of, yet. I say yet, because there's only so many 200 3 speeds left, unless we want to start digging them up out of landfills, or maybe get China to send some back, before they're turned into H.F. tools.
Old 10-10-2019, 02:10 PM   #8
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
2019 NHRA Rules
Super Stock
Section 12A
Page 5
Page 154 overall
Does anyone use the OD feature on the 3 speed plus Overdrive transmissions?
D
