Old 10-09-2019, 11:18 PM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default 95 lt1 block?
Is it legal to run a regular old style Chevy block rather than a LT1 block in a 98 Camaro in stock eliminator ?
Kdw1403 is offline   Reply With Quote
Old 10-10-2019, 02:58 AM   #2
Greenlight
Liked 81 Times in 23 Posts
Default Re: 95 lt1 block?
Yes, as long as the main bearing size is the same. In other words, you can't run the small main journal Chevy pre-1968 block.
The blocks are NOT a direct replacement. The LT block has a completely different cooling routing system, unique front drive distributor, different timing cover, etc.
Others have converted an LT engine to a earlier generation block, but it's not that easy.
Greenlight is offline   Reply With Quote
Old 10-10-2019, 09:39 AM   #3
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
Maybe in Superstock, but in stock you must use the Opti-spark, which requires the LT1 block.
Old 10-10-2019, 10:05 AM   #4
Whalen3186
Liked 109 Times in 32 Posts
MSD and stock GM Opti-spark's will work the traditional style sbc blocks.
Drew Whalen Stk 3186
Whalen3186 is offline   Reply With Quote
Old 10-10-2019, 11:09 AM   #5
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Inquiring minds want to know how to do this ? What would you use as a waterpump ?
Old 10-10-2019, 11:41 AM   #6
Whalen3186
Standard sbc water pump with spacers to clear distributor. Water flow can be either direction, these motors don't see enough temperature to need the reverse cooling.
Old 10-10-2019, 11:49 AM   #7
ss3011
ss3011's Avatar
Seems to me the issue is how to adapt the front cover to the old style block . Isn't the shape and bolt pattern very different . Also wouldn't the water in the heads be deadheaded .
Old 10-10-2019, 12:40 PM   #8
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Rare they are but they did make Bowtie LT-1 blocks....
They were made in a std 4" bore size and a larger bore....4.125"
I took delivery of 1 for someone who found 2 or 3 available somewhere.
I was aware that Bowtie blocks could be adapted for use in SS with a belt drive distributer but never knew of or saw one in Stock adapted somehow to drive an Optispark distributer with the LT-1 timing cover....on a std type block....
An Interesting topic....
Rich Biebel
S/C 1479
Stock 147R
Old 10-10-2019, 12:57 PM   #9
KRatcliff
Liked 534 Times in 143 Posts
Drew is right and it isn't all that complicated. You do have to weld up the water passages on the LT1 heads (legal by tech) and fill in the top of the timing chain cover with epoxy for the LT1 to adapt to a SBC block. The LT1 timing cover has somewhat of an overbite is the best I can describe it when placed on a SBC block.
There are two water passage plugs on the heads that you remove with an adapter that bolts on to adapt to an -AN fitting. A standard SBC water pump with enough spacers to make a good border wall will be necessary to clear the Optispark or MSD. I suggest that you use the largest water return lines and -AN Y fitting coming from the heads that will fit.
Hope this helps.
KRatcliff is offline   Reply With Quote
Old 10-10-2019, 01:02 PM   #10
KRatcliff
I forgot to mention that the reverse cooling for these engines was a way to somewhat battle detonation on pump gas and utilizing higher compression for a street car. We can and do run much higher octane with our racing fuel so it is a moot point on how it cools from the top down or bottom up.
Just make sure it cools.
