Hi All ! Chevy 12 bolts , solid sleeve ( MW #58905),ritchmond gear 5.57, new pinion bearing . Rotating torque 25 inch pound,.New Gm nut ,Pinion come loose again . What going wrong?
Any input welcome! |
Liked 263 Times in 68 Posts
How much did you torque it to? They need about 250 ft lbs.
John Dinkel 3295 STK |
Liked 883 Times in 237 Posts
Pinion nuts are really designed for one time use only ,if it was not tightened enough the first time and came loose ,it should be replaced. .
Even though they are a prevailing torque locking nut , I always red loctite them. 225-250# with a solid sleeve.
Liked 799 Times in 236 Posts
Check that the washer is seating correctly in the pinion flange and that it's thick enough so the nut isn't bottoming out on an unthreaded portion of the pinion. I had one set where the pinion threads stopped about .250 from the splined portion of the pinion.
Those solid spacers can fake you out on bearing preload. I don't use any spacer or crush sleeve...just a little red Loctite on the pinion where the front bearing locates. If the pinion flange fit on the pinion is a bit sloppy, red Loctite or a couple of peens on the pinion nut can help. Hope this helps. -Al
"That'll never work....." |
Liked 358 Times in 83 Posts
Exactly this^^^^^
Liked 280 Times in 139 Posts
What I do on mine is grind a V on the start of the pinion thread,set preload,and then stake the nut into the groove.No spacer or crush sleeve.Never had a problem...gsa612
Liked 564 Times in 66 Posts
Maybe I'm doing it wrong, but using a solid bearing spacer I torque my MW nut to 250+/- with an electric impact. I then fill the void between the nut and the yoke with Permatex Ultra Grey. I have been doing my own 12 bolt rear ends for 15 years, and never had any issues (R&P or otherwise).
It does however take some time to dig out the Ultra Grey when it is time to remove the pinion gear. |
