Old 11-07-2019, 05:41 PM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default SBC Pink Rods
How good are the GM SBC Pink Rods?
Seems everyone used them through the 90's successfully.
Have a set in the 350/255 Stocker Engine.
Are they good above 7000 rpm?
Getting different feedback.
Is there a preferred Piston Rod Combination?
Old 11-07-2019, 06:22 PM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: SBC Pink Rods
That was about the best you could do 20-30 years ago.....but I'd never use them today with aftermarket rods legal and available at reasonable prices.
By the time you fully prepped a stock rod for race use you would spend a fair amount of $$ and would be far better off buying aftermarkets...
Manley rods would be preferred....
Eagles also have worked in a number of engines I built or raced myself and never had one fail...
Stock GM rods will fail way easier than aftermarket...
Rich Biebel
S/C 1479
Stock 147R
Old 11-07-2019, 06:40 PM   #3
richie 2
Liked 205 Times in 93 Posts
and try to put togeather a set of eight that clean up size/length/weight/centered pin bore wise...quite a difficult job.
Old 11-07-2019, 07:28 PM   #4
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
As with any used rods, unless you have owned them since new, its unknown how many cycles they may have been previously subjected to. Not worth risking "catastrophic failure" when so many decent alternatives exist. Sell them to a Corvette or Camaro purist and move on IMHO.
Old 11-07-2019, 07:37 PM   #5
Alan Nyhus
Liked 799 Times in 236 Posts
Well, you've got them already so that's a plus, provided you don't go upside down getting them in shape.
If your goal is for something modest, that's one thing.
If you're going have the intake/heads/cam combo that gets you north of 7,000 regularly, that's another thing.
The Manley Sportsmaster rods are a great value:
http://www.manleyperformance.com/dl/cat/rods.pdf
"That'll never work....."
Old 11-07-2019, 09:07 PM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,930 Times in 580 Posts
Properly rebuilt with some good bolts and resized they will hold up just fine. I ran stock rods in my super stock engines for years with no failures. When I had a stick in the car I left the line above 9000 rpm and crossed over 8000. Now it’s not worth spending the money on an old rod Whalen a new set is not much more. The Manley sportsmaster is a good rod for the cost.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 11-07-2019, 10:03 PM   #7
carl hinkson
Liked 18 Times in 10 Posts
The older version was not as good as the later ones after 1979 more material around the rod bolts and they changed the beam as well. They were only a 1038 steel same as the steel cranks were made out of.
carl hinkson is offline   Reply With Quote
Old 11-08-2019, 02:17 AM   #8
Adger Smith
Liked 880 Times in 311 Posts
GM Steel cranks were 1053 Steel
Adger Smith (Former SS)
Old 11-08-2019, 11:03 AM   #9
Dan Fahey
Dan Fahey's Avatar
Thanks
The Pink Rods are in the engine.
Originally prepped by Budd Rowe.
Just had Rockville Ring and Bearing go through the block.
Old 11-08-2019, 11:03 AM   #10
HP HUNTER
Liked 372 Times in 129 Posts
Yes.....this will be your problem
