building a 408W bracket motor 12.5:1 compression and hydraulic roller cam. going in an 1/8th mile footbrake care.
just wondering what everyone runs for oil and filter |
Liked 263 Times in 68 Posts
Amsoil, Valvoline, Mobil 1. Wix filters
John Dinkel 3295 STK |
Liked 1,929 Times in 580 Posts
Lightning racing oil and system 1 oil filters. I don't use any passenger car oil or filters on my race engines.
Mike Pearson 2485 SS |
Liked 262 Times in 124 Posts
427 windsor Schaeffers 20-50 Wix filter with a Melling select oil pump has 62lbs cold 58 hot
Liked 3,181 Times in 972 Posts
WIX/NAPA and Valvoline VR1 Racing Oil (no passenger car oil). Have used Mobil 1 Full Synthetic in bracket motors without issue but no way turning 8K thru the lights.
Liked 133 Times in 76 Posts
Research what your cam/lifter manufacturer recommends I have heard hydraulic rollers are picky on oil weights. For a Filter Wix is a good filter and I'd look into Motorcraft. They used to be top of the line, don't know who makes them or what the ratings are.
Liked 54 Times in 24 Posts
If you're building a Hydraulic Roller Engine, I'd suggest using Johnson Lifters, the short travel Race versions. With the correct Valve Springs are stable up to 8000 RPM and higher.
As for oil, a good Racing Synthetic, such as JR1, HPL , Red Line. If your bearing clearances allow, use a 5/20 or 5/30 weight. The lighter weight returns to the pan quicker and disperses air bubbles quicker as well. Also the lighter oil may protect better than a heavier oil that could be compromised with aeration. And... WIX Racing or Moroso Oil Filters My 2 cents.
Todd Gross 3323 FS/E,F Last edited by Todd Gross; 11-13-2019 at 10:35 PM. |
#8 | |
Liked 184 Times in 113 Posts
Not road racing and figure wears engine less with all the cold starting. |
