Old 11-13-2019, 10:39 PM   #11
SDT1DYI
Liked 455 Times in 147 Posts
Default Re: What Stock rules would you change?
Allow pump 91 octane gas. Many low compression stocker engines will run on it and could be an important cost saving to many class racers.
Steve Teeter. Stk SS. 6380/6283
SDT1DYI is offline   Reply With Quote
Old 11-13-2019, 10:46 PM   #12
Originally Posted by DYER View Post
roller lifters for all engines no more broke lifters or worn out camshafts less engine blow ups
Sure. Why stop there, though? I think that 55 Chevys should get the entire top end from the baby Caprice taxi 265..Computer and all.
While we're at it, it's not fair that the 55 cam only has .330 lift. It should get the .450 lift cam too....in the interest of fairness and equality ,of course.
Old 11-13-2019, 10:47 PM   #13
SDT1DYI
Allow 91 octane pump gas. Would save some a lot of expense that have low compression engines.
Steve Teeter. STK SS 6380/6283
Old 11-13-2019, 10:55 PM   #14
Bob Sherwood
Liked 388 Times in 60 Posts
Smile Re: What Stock rules would you change?
I'll order the pizza, this could get interesting !!!
Bob Sherwood is offline   Reply With Quote
Old 11-13-2019, 11:02 PM   #15
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
While keeping the basic premise of 'Stock' and not morphing into Super Stockers, what Stock rules would you like to see changed?
Think about things that would make the cars easier to build, certain areas less costly, allow for a bit more experimentation and make the cars safer.
OK, I'll start:
- Relax the rules on oil pans
- Allow spacers, etc. between the carb(s) and intake
Bring back the pajama pants for all stockers under 135 mph. Comfort, fashion worth a good tenth in certain D-1 Novas
Eric Merryfield 1883 STK
Old 11-13-2019, 11:58 PM   #16
CWhitney
CWhitney's Avatar
Liked 12 Times in 6 Posts
Real tech inspections at every race
All run fields
random pairings
15HP off early combos
no air shifters
CWhitney is offline   Reply With Quote
Old 11-14-2019, 05:27 AM   #17
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
OK, I'll start:
I like relaxing the oil pan rule, carb spacers and 91 pump gas. The air the engine ingests still has to pass thru a stock carb and intake. Pump gas would be cheaper but might be harder to enforce. I ask the buyer at a oil & gas distributor what brand they used, his response was "whatever is cheapest", But I think that could be made to work. Roller lifters will make things easier but not cheaper, IMHO. They could make them stock lift roller cams. Yes stockers today are what Super stock was years ago but when have rules ever been rescinded? Yes its happened but its rare. These are race engines, we'll never "eliminate" breakage. We Can ease it though. I like qualified pairings. I get the idea behind lockup converters but I'm a No on this.
Dave Noll, EF/S ,?/SA 6526
Old 11-14-2019, 08:42 AM   #18
Billy Nees
Liked 7,777 Times in 1,742 Posts
UUUUUGGGGGHHHHH, 1973-4-5? (a little help here)
All of the Stockers became SSers and Stock Eliminator became "PURE" Stock.
Not really a fun time to have a Stocker.
Billy Nees 1188 STK, SS
Old 11-14-2019, 09:36 AM   #20
Lee Valentine
Liked 319 Times in 68 Posts
True start.
Lee Valentine 1661 STK
