#41 | |
Liked 44 Times in 19 Posts
I ran a 65 Bel Air 4 door sedan with a 230 and a 3 speed in O/Stock. Best time was a 17.6 at Island.
Marty Knox 3071 STK Last edited by Marty Knox; 11-15-2019 at 07:12 PM. Reason: Added info |
#42 |
Liked 327 Times in 121 Posts
#43 | |
Liked 4,379 Times in 502 Posts
Without the crank trigger you can't get a clean signal to the computer. I have spent lots of time and money trying to shield wires, have clean grounds, Magnecor plug wires, etc. but that stuff doesn't work. My tach signal is awful on the data logger and RPM jumps all around especially near finish line. Can't take advantage of my NHRA Accepted EFI system that does almost everything based on RPM. How will I ever get my E-shift to be accurate with this messy tach signal? I know I should have built a different combo silly me.
PS some rule changes I forgot: Fix the following stupid indexes K/SA to 12.60, L/SA to 12.75, M/SA to 12.90 and so on.. oh yea, NHRA.TV on Thursdays should be a rule too! |
#44 |
Liked 905 Times in 193 Posts
50 points for setting a record.
Bob Don 128 SS |
#45 |
Liked 129 Times in 53 Posts
No Headsup with newer cars??
#46 |
Liked 5,140 Times in 1,962 Posts
I suppose "Mr Clean" has that option..Can't beat them..Try joining them
#47 | |
Totally agree on the index change.
#48 |
[QUOTE=Mark Yacavone;601930]Bobby , You have an E-shift on a 302? See post # 59 on the Enforcement thread.
No I’m joking I think it’s dumb and I don’t use it. I use B&M hammer and miss shifts perfectly fine on my own lol. |
#49 |
Liked 61 Times in 12 Posts
The 2 year change the belts. The 5 year change the trans shield. Is that piece of equipment really going to go bad? And enforce the rules that are already in the book.
John Bender, 1969 E/SA
John Bender 1969 STK |
#50 |
Liked 240 Times in 112 Posts
I had a similar problem with my Racepak. I don't know about the Magnecor's but I put a new set of the MSD Super conducters on mine and the rpm trace cleaned right up.
Dave Noll, EF/S ,?/SA 6526 |
