Old 12-13-2019, 11:24 AM   #11
340Cuda
Liked 801 Times in 338 Posts
Default Re: How Much Does Density Altitude Affect ET
Originally Posted by Ralph A Powell View Post
Percent of oxygen changes can have a big impact and since very few measure this the basic numbers can remain the same but the percentage of oxygen can change and have a large impact!
So at the same DA the percent of oxygen can be different?
How do you measure the percent of oxygen?
Thanks
Old 12-13-2019, 12:42 PM   #12
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Thanks
There are many different combinations of Temperature, Relative Humidity, and Barometric Pressure that will give you the same Density Altitude, say 2500 feet. The car should perform similarly in any of those combinations that equate to a DA of 2500 feet, but it can vary depending on the exact makeup of those measures.
I'm pretty sure your weather monitor needs to have an oxygen sensor if you want that info.
S/ST 51
S/C 53
Old 12-13-2019, 12:44 PM   #13
Mike Pearson
Mike Pearson's Avatar
Liked 1,929 Times in 580 Posts
Thanks
You have to have a weather station that measures the percent of oxygen. I know Altronics has them as an option.
I mostly look at the humidity and the barometer to make comparisons. The 327 engine that I am running is much more difficult to dial than the 350 that I have. Must have something to do with the shorter stroke.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 12-13-2019, 01:24 PM   #14
SSDiv6
Liked 1,583 Times in 582 Posts
Patrick Hale's book is very helpful and has lots of information on this subject.
http://www.dragracingpro.com/site/90...ooks.html#2859
Old 12-13-2019, 01:34 PM   #15
pmrphil
Liked 348 Times in 152 Posts
the link doesn't work for me ???
Phil Molski
PMR Performance
S/C 1623
Old 12-13-2019, 02:21 PM   #16
340Cuda
Try this one...
http://www.dragracingpro.com/Books.html
Old 12-13-2019, 05:44 PM   #17
Ralph A Powell
Liked 225 Times in 136 Posts
Thanks
With a oxygen meter there was a company in the Baltimore area the sold them. I will do some digging and post there name.
Old 12-13-2019, 06:07 PM   #18
Pete Lanciers
Pete Lanciers's Avatar
Liked 627 Times in 156 Posts
You can probably guess one of my New Year’s resolutions.
Right there with you Jimbo, I just recently came to the same conclusion!
Pete Lanciers
PAL Automotive Racing
Stock 7801
Pete Lanciers is offline   Reply With Quote
Old 12-13-2019, 07:42 PM   #19
pmrphil
thanks
Phil Molski
PMR Performance
S/C 1623
Old 12-13-2019, 07:55 PM   #20
vic guilmino
Liked 56 Times in 21 Posts
What do you use.
DA OR CF
AND WHY
Vic Guilmino 1129 STK
