Liked 56 Times in 21 Posts
How far from the end of header should the 02 be placed
Vic Guilmino 1129 STK |
Liked 165 Times in 59 Posts
most are as far back in the collector as you can get,, but a true reading should be in the primary tube of the leanest cylinder for your combo
collector readings will be leaner than in a primary tube ,,so when doing a dyno session apples for apples if your on the dyno use the same sensor location |
Liked 124 Times in 39 Posts
Two inches beyond the merge. If in SS, you want them pre the pan evac.
Sean Cour T6066 ladle |
To add to what Sean said, 2" beyond the merge and it helps if you have somewhere in the neighborhood of 14 to 18" of collector beyond that.
Liked 269 Times in 99 Posts
Within 20 inches of the exhaust valve will be more accurate see less fresh air.
Liked 171 Times in 51 Posts
Tagging onto this thread. I put a different set of headers on my car that use slip tubes. I noticed the tube my sensor is in is leaking slightly. What can I use to seal it?
Kelly |
Liked 535 Times in 110 Posts
Permatex offers a high heat/sensor safe sealant.
Jim Kaekel 3836 STK |
My are 9 from the end of collector
Liked 57 Times in 33 Posts
Mine are about 4” from the end. Never dynoed it, found the happy spot (fasted tune up down the track) and monitor it now for changes.
Duane Eiskant 1354 Stock/Super Stock |
