Old 01-07-2020, 03:05 PM   #1
bykr
Liked 167 Times in 81 Posts
Default Thoughts on lightened ring gears?
I'm considering purchasing a lightened 9" gear set, my concern is it's for a super stock stick car and I'm wondering about deflection being an issue. Any thoughts or experience would be appreciated.
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 01-07-2020, 03:44 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Thoughts on lightened ring gears?
All I ever saw from my lightened gear sets was shorter life. No performance gains. I even wasted money on track rental, swapped gear sets at the track. Ran both gear sets back-to-back within an hour. Same ET & MPH. Told myself “Oh well,?It can’t hurt”. Wrong.
Ed Wright 4156 SS/JA
Old 01-07-2020, 03:46 PM   #3
Ed Wright
Ed Wright's Avatar
Also, saw no up or down side to my light spool. Many “Has to be worth something” pieces on my car.
And, I’m very old and from Oklahoma, so........
Old 01-07-2020, 04:01 PM   #4
Jim Caughlin
Liked 805 Times in 245 Posts
I very much doubt you will see any measurable difference in performance, same with gun drilled axles, alum spools and lightweight driveshafts. I did a same day back to back alum vs steel driveshaft test (13# vs 10#) and saw zero performance difference. That being said, unless you are on a budget, I would do everything within reason to reduce rotating weight regardless. For what it's worth, I just ordered a new 3rd member and paid the extra for the lite weight parts so am taking my own advice.
Jim Caughlin
SS 6019
Jim Caughlin is offline   Reply With Quote
Old 01-07-2020, 04:44 PM   #5
Strawboss
Liked 2 Times in 2 Posts
We have run back to back a lightened ring gear and a regular ring gear and found no gain what so ever and this is with SS stick car. Save your money just get a regular gear set.
Strawboss is offline   Reply With Quote
Old 01-07-2020, 05:40 PM   #6
Lee Valentine
Liked 319 Times in 68 Posts
Never saw gains on rotational parts close to the centerline if I have posted this right. You start to see benefits when you get into tires and wheels etc. That being said anything lighter that doesn't hurt durability can't be bad,depends on your budget.
Lee Valentine 1661 STK
Old 01-07-2020, 08:33 PM   #7
bykr
Thanks for the info guys. I think I'll pass on the lightening process.
Old 01-07-2020, 10:57 PM   #8
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Thought on something Billy has talked about. If someone were to change to All of the lite stuff in the rear, doing the A-B style test. Any difference in ET?
Dave Noll, EF/S ,?/SA 6526
Old 01-08-2020, 09:34 AM   #9
ron mattson
Liked 67 Times in 30 Posts
Changing from a 10 bolt 8.5 diff to a 12 bolt
Both with light components and set up the same
way there is a difference slowed .04-.05
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 01-08-2020, 12:56 PM   #10
Jeff Stout
Liked 704 Times in 281 Posts
Aluminum driveshaft, rifle drilled axles, light ring gear 14 lbs lighter and zero gain in ET on a 3500 lb BBC
