Old 01-13-2020, 09:06 AM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default Swing out bar.
Is it legal in stock and super stock to have a swing out door bar on the driver side and passenger side?
Kdw1403 is offline   Reply With Quote
Old 01-13-2020, 09:19 AM   #2
Billy Nees
Liked 7,925 Times in 1,760 Posts
Default Re: Swing out bar.
Yup.
Billy Nees 1188 STK, SS
Old 01-13-2020, 10:23 AM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Like Billy said but only on 8.50 and slower roll cage certs.
I've installed many of them .
I highly recommend using the billet clevis sold by Applied Racing Technology.
Simple and effective. Much less vertical slop in movement.
https://www.appliedracing.com/roll-b...ar-kits-1.html
Tom Goldman is online now   Reply With Quote
Old 01-18-2020, 06:56 PM   #4
Kenney Kelley
Liked 72 Times in 36 Posts
Thank you Tom for the heads up about the ART swing out kit after reading your post I called ART and ordered a kit and we installed it in our 95 Camaro it was a simple installation. Kenney Kelley
Kenney Kelley is offline   Reply With Quote
Old 01-19-2020, 02:20 PM   #5
Tom Goldman
Kenny , some of the little tricks i do with those clevis include beveling the edged of the top pieces so they engage each other more easily , and using a .030" hardened valve spring shim in the bottom pivot to act as a bearing,I found nickel antiseize works best to lube it.. This allows you to keep the bottom bolt tighter and make the bar close easier with less movement up and down.
another thing you can do is to drill and tap the slot in both clevis' for a 10-24 allen cap screw that can act as a limiter both opening and closing , just have to position it carefully. Makes closing a lot easier and keeps the bar from rubbing on the door panel.
.Try to keep the lower pivot as close to bottom as possible to minimize any flexing. .
Old 01-20-2020, 01:21 PM   #6
2021STK
Liked 17 Times in 14 Posts
Welded a small strip of metal on the inboard side of the upper clevis to prevent the swing out bar from going past the pit pin center.
Dave Outten
2222 S/SS/SST/SG/HR
2021 S 1968 SS 1969 SR 1966 1990 Bracket
2021STK is offline   Reply With Quote
Old 01-20-2020, 11:39 PM   #7
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Swing out bar.
Kenny, I just put one in my Stocker because of my back surgeries this past year. Tom's remarks above are spot on! ART makes the finest and strongest unit available. I looked at them all before I pulled the trigger! I should have done it a long time ago! Jim
