Old 01-22-2020, 10:39 AM   #21
Jeff Stout
Liked 704 Times in 281 Posts
Default Re: Question on loosing fuel pressure going down track.
Originally Posted by Hacksaw View Post
If you are using a fuel filter, check the Microns.
It is a Summit -8 inline 40 micron filter
Old 01-22-2020, 11:37 AM   #22
Ed Wright
Ed Wright's Avatar
Originally Posted by Jeff Stout View Post
1.88 60ft 14.50 ET.
Won’t be G forces.
Ed Wright 4156 SS/JA
Old 01-22-2020, 04:34 PM   #23
jmantle
Liked 172 Times in 81 Posts
Have you checked the pressure before the regulator? Most pumps put out about 15 PSI.
You may have a low pressure pump not designed to use with a regulator or the pump is no good.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 01-22-2020, 07:02 PM   #24
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Side note is the o2 is going from 13.5 to 11 in high gear.
Trust the sensor, there isn't a problem. Its 11:1 in high gear. My cars AFR gets leaner as RPM increases an gets richer at each shift. (completely different carb)
Dave Noll, EF/S ,?/SA 6526
Old 01-22-2020, 07:20 PM   #25
MRE 7171
Liked 95 Times in 24 Posts
Jeff did you get a chance to check the volume in a fuel jug for 60 seconds at the front of the car and what volume did you get?
MRE 7171 is offline   Reply With Quote
Old 01-22-2020, 07:45 PM   #26
Jeff Stout
I just did now im right at a gallon in 60 seconds. That was tested using line right at carburetor
Old 01-22-2020, 08:12 PM   #27
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
On a free flow test it should be a gal.in 30 seconds especially with a Q-jet...gsa612
Old 01-22-2020, 08:14 PM   #28
Danny Ashley
Liked 110 Times in 29 Posts
Should pump a gallon in 30 seconds. I think you just found your problem.
Danny Ashley is offline   Reply With Quote
Old 01-22-2020, 08:25 PM   #29
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Its weird that the O2 sensor goes rich , sounds like some work needs to be done to straighten out the fueling of the carb . That being said the carb is using more fuel than can be supplied to it , so the pressure drops . My recommendation is to figure out what's up with the carburetor , but also make sure your fuel system is up to the task . My Q-jet is fed from a BG400 pump through a dash 10 line , and stays right at 6.5 psi throughout the run . Dyno pulls show the A/F ratio varies from 12.8 at 5000rpm to 12.4 at 7400 rpm .
Old 01-22-2020, 09:25 PM   #30
Agree..I've had cars under 25 sec.
BTW, I was just giving Jeff a hard time. Sorry some of you missed this whole sordid tale, for 5 years ...Check out the build section once in a while ;-)
