#41 | |
Liked 88 Times in 43 Posts
#42 |
Liked 81 Times in 45 Posts
A lean miss-fire will show a rich condition due the un-burned fuel leaving the combustion chamber.
#43 | |
Liked 62 Times in 29 Posts
A severely rich mixture will also show as a lean condition on a wideband sensor. Spark plugs and header tubes don't lie.................. But the widebands can. |
#44 | |
Misfires do look lean.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 01-23-2020 at 10:02 PM. Reason: Can’t type |
#45 |
Liked 240 Times in 112 Posts
YES, a mis-fire will show lean on a wideband sensor. All that sensor reads is oxygen, when there's a mis-fire, oxygen isn't getting used on that cycle so it passes through the engine un-used. A wideband sensor in a collector is seeing the average of 4 cylinders. If say theres a distribution problem in an intake manifold, the average of the 4 could show close to perfect, but with the bad intake it may have a severely lean hole. The better way to check would be to weld 8 bungs into the primary tubes of the headers and either install 8 sensors or rotate 1 sensor over 8 passes down the track.
Dave Noll, EF/S ,?/SA 6526 |
#46 |
Liked 225 Times in 136 Posts
#47 | |
The too rich showing lean though, that can be tricky to diagnose. A N/A engine will typically be falling on it's face though, but on a forced induction it can be misleading, therefore plugs and collectors are the best thing to determine the root cause. |
#48 |
Liked 706 Times in 283 Posts
On my other car I use a 2 step and car goes rich staging with trans brake and 2 step. Takes about 1.5 seconds to clear up when released.
Maybe 2 types of misfires. One with plug not firing and car goes rich , the other if injected and injector does open then car goes lean? IDK Last edited by Jeff Stout; 01-24-2020 at 12:13 PM. Reason: more |
#49 | |
Just remember, a wideband sensor only measures oxygen inside the exhaust system, it knows nothing about fuel inside the pipe. |
#50 |
Ok here is the fix. I bypassed summit inline filter and changed vent line on fuel cell. 1 gallon in about 40 seconds and today's pass with leaner secondary rods im at 5psi in high and went 12.1 afr. May night be perfect but improved .3 mph
I want to thank everyone for the suggestions as they were helpful in chasing problem. Last edited by Jeff Stout; 01-25-2020 at 03:24 PM. Reason: More |
