Old 02-08-2020, 12:31 PM   #1
Charlie Laraia
Default 400 Cubic Inch Dart Block Small Block Chevy Motor
400 cu. In. Small Block Chevy Motor
For sale carb to pan
10.3 compression-pump gas motor
Dart 31131213 LiL M Block
Scat 4-350-3750-6000-3S Super Lite Crankshaft
Scat 2-350-6006-2100SA Con Rods
SRP 231308 flat top pistons
Airflow Research 235 heads
Comp Cam solid roller cam
264 deg. Intake, 271 deg. exhaust duration, .673 lift
Comp Cams 96818B-16 Elite bronze bushed roller lifters
Comp Cams chrome moly pushrods
Jesel KSS-416060 1.6 shaft rockers
Airflow Research valve covers
Edelbrock 2925 Super Victor manifold
Holley 950 HP 0-80496-1 Carb
MSD 8570 Distributor
MSD Crank Trigger system
Milodon 30900 Oil Pan
Milodon oil pump and pickup
Rollmaster timing chain set
ATI Balancer 917781
Moroso 4 vane vacuum pump
Moroso vacuum pump drive
MSD Dyna force starter 5095
168 Tooth SFI Flex plate
This is a great motor that was built to run trouble free as a street/race motor.
I used it mainly to go to cruise nights.
No spare time limited me to going to an occasional track rental.
It has low street miles and small number of runs on it.
It ran a best of 10.15 @130 in my 3300 lb car.
Parts to build would be over $15K.
Will sell for $9250
I’m in Connecticut.
Call or text: 860-614-2252
Email: 1984iroc@gmail.com
Charlie Laraia is offline   Reply With Quote
