Old 02-10-2020, 03:24 AM   #1
Brad Zaskowski
Brad Zaskowski's Avatar
Liked 130 Times in 20 Posts
Default Engines, wheels, center section, intake, driveshafts
For Sale:
1966 283 220/238 SS or 220/230 GT Super Stock engine
Has been -.93 under in GT/M, all the best parts, very reliable engine.
-Bowtie block
-Jesel lifters, belt, rockers
-BME pistons
-Aftermarket crank
-Heads up heads and intake
-50mm cam
-baseball bats for pushrods
-Pac springs
-Manly Valves
-ATI balancer
-MSD crank trigger
$15,000
327 041 head big valve super stock engine, can be run with 4gc , Holley 585, or q-jet carbs. Very versatile combination I could run from the old GT/D down to GT/H just changing carb and weight. Engine has been -1.00 under, went 9.492 in the old GT/E class (now GT/I), currently the motor has one head that leaks and engine would need to be freshened up. Last race out this motor with leaking head won 2016 JEGS sport nationals.
-Bowtie block
-JE pistons
-Heads up heads (1 head is new and only ran 1/2 season) and intake
-50mm cam
-7/16 tapered pushrods
-Pac springs
-Manly Valves
-Aluminum oil pan
-ATI balancer
$11,000
SOLD-Mickey Thompson drag wheels
9" ford nodular steel center section
-Strange aluminum pinion support
-Mark Williams 35 spline steel spool
-1350 yoke
-currently set up with 6.50 gears
-Plastic shipping container included
$800
Edelbrock SBC Victor "E" intake by heads up. set up for heads up non raised port heads. Was on our 305 engine.
$500
Steel driveshafts 3 1/2" diameter-
43 5/8" center of joint to joint, 1350 ends Jerico yoke $125
40 7/8" center of joint to joint, 1350 ends Jerico yoke $125
Head castings
3911032 $100 pair
Call text or email for more information (616)437-4958 brad@zaskowskibuilders.com
I can deliver any of the items to the upcoming D2 races at SGMP or Gainesville.
Brad Zaskowski 3697 STK, SS
Brad Zaskowski is offline   Reply With Quote
Old 02-10-2020, 06:21 AM   #2
richie 2
Liked 205 Times in 93 Posts
Default Re: Engines, wheels, center section, intake, driveshafts
pm sent
richie 2 is online now   Reply With Quote
