Liked 130 Times in 20 Posts
For Sale:
1966 283 220/238 SS or 220/230 GT Super Stock engine Has been -.93 under in GT/M, all the best parts, very reliable engine. -Bowtie block -Jesel lifters, belt, rockers -BME pistons -Aftermarket crank -Heads up heads and intake -50mm cam -baseball bats for pushrods -Pac springs -Manly Valves -ATI balancer -MSD crank trigger $15,000 327 041 head big valve super stock engine, can be run with 4gc , Holley 585, or q-jet carbs. Very versatile combination I could run from the old GT/D down to GT/H just changing carb and weight. Engine has been -1.00 under, went 9.492 in the old GT/E class (now GT/I), currently the motor has one head that leaks and engine would need to be freshened up. Last race out this motor with leaking head won 2016 JEGS sport nationals. -Bowtie block -Jesel lifters, belt, rockers -JE pistons -Heads up heads (1 head is new and only ran 1/2 season) and intake -50mm cam -7/16 tapered pushrods -Pac springs -Manly Valves -Aluminum oil pan -ATI balancer $11,000 SOLD-Mickey Thompson drag wheels 9" ford nodular steel center section -Strange aluminum pinion support -Mark Williams 35 spline steel spool -1350 yoke -currently set up with 6.50 gears -Plastic shipping container included $800 Edelbrock SBC Victor "E" intake by heads up. set up for heads up non raised port heads. Was on our 305 engine. $500 Steel driveshafts 3 1/2" diameter- 43 5/8" center of joint to joint, 1350 ends Jerico yoke $125 40 7/8" center of joint to joint, 1350 ends Jerico yoke $125 Head castings 3911032 $100 pair Call text or email for more information (616)437-4958 brad@zaskowskibuilders.com I can deliver any of the items to the upcoming D2 races at SGMP or Gainesville.
Brad Zaskowski 3697 STK, SS Last edited by Brad Zaskowski; 02-18-2020 at 11:28 PM. |
Liked 205 Times in 93 Posts
pm sent
