Liked 75 Times in 28 Posts
Looking for recommendation on which lifter and why?
Trend or Precision? Would you get them DLC coated? |
Liked 72 Times in 27 Posts
They will be on a steel cam.
Liked 169 Times in 53 Posts
why can you not run the coated lifters on a cast cam.?
Bill Bogues 4696 STK |
![]() You should be more specific as regards to the type of coating. There are some coatings that can be used with cast camshafts. However, DLC coated lifters can only be used with a properly finished tool steel camshaft core. |
Liked 132 Times in 27 Posts
Would you get the EDM hole in the face of the lifter?
Liked 507 Times in 116 Posts
Ppp lifter have a coated lifter with a coating that is safe for a cast cam. In my spare engine I took out the shubeck grenades and installed them on a cast cam. Broke them in as if it was a new cam and lifters with break in oil. Valve setting never moved. Took them all out after to inspect them and they looked like they came out of the box.
68 Chevy11 327 F/S |
Liked 67 Times in 30 Posts
On billet or tool steel cams I would run the
dlc lifters with no oil hole as the hole just creates a place for the dlc to not stick or flake off. On cast cams I would use the ones with the hole and have coated with a lubricity coating like Micro blue, have the cam nitrided and coated also. And as Bob said Pppc has a dlc that will work on a cast cam also.
Ron Mattson 5015 STK |
