#11 |
Liked 28 Times in 9 Posts
The Jack Davis headers were 1 1/2 to 1 5/8 to 1 3/4 ;Stahl 1 5/8 were quicker . Jere recommended playing with extensions as opposed to a step design which I did .
#12 |
Liked 7,723 Times in 1,738 Posts
Jere wasn't a real fan of stepped headers. He also wasn't a fan of merged collectors. He said, "if your car picks up with a merged collector then your primary tube is too big".
#13 |
Yep!
Ed Wright 4156 SS/JA |
#14 |
Liked 19 Times in 10 Posts
1 1/2” x8”Lg. to 1 5/8”Lg. x8” to 1 3/4” is the best I have found.
James Jeschke Jr. #1603 I/S |
#15 |
Liked 799 Times in 236 Posts
Are you looking for a conventional header or a tri-y?
"That'll never work....." |
#16 |
#17 |
Ya know, you don't post with a real name so I can't tell if you're a Newbie or a veteran of Stock. If this is your first build, then good luck picking the "correct ones" the first time around. Heads, intakes, carbs and cams change over time and that will change the working range of this combo. Unless this is a "top shelf, best of everything" build by a known builder, who knows the combo, then I would stay away from a tri-y header to begin with.
#18 | |
![]() Just my experience with them, FWIW. For a conventional 4-1 header, I'd happily pick up the phone and order a set of 1 5/8" and go racing: https://acpheaders.com/ Ben Line is a real craftsman and makes great headers: https://www.headersbyben.com/
#19 | |
Liked 165 Times in 51 Posts
Glen DeMenge 1969 Camaro Stock Eliminator |
