Liked 196 Times in 29 Posts
Its time to sell some parts that I will never use, they need a new home:
Stahl headers for a Big Block Chevy Gen 2 Camaro - 2 inch primary tubes. They are ceramic coated with 8 oxygen sensor bungs and 8 thermocouple ports, one in each primary tube. They have some typical dings and dents "SOLD" Chevrolet Intake Manifold, casting number 3933198 used on the L88/ZL1 Big Block Chevrolet Engines. The casting date is 10-30-69. This manifold is in excellent condition and also has GM thermostat housing P/N 3877660 attached and is also in excellent condtion, even the throttle return spring hole is still intact. $795.00 1967 L88 Chevrolet Intake manifold for a Big Block Chevy. The casting date is 9-26-66. It is in very good condition for being over 50 years old. The only damage is the knob of aluminum on the front driver corner is not there, but a certified welder could repair this. Note that the plenum is open and was cast this way when manufactured. It has two casting numbers 3885069 and 3886093, one next to the other. $795.00 Casting Number 3919842 aluminum closed chamber cylinder head for a Big Block Chevy. The casting date is 10-1-68. This is a single cylinder head that has damage in one of the intake ports and combustion chamber. It appears as though it dropped a valve at some point, but in my opinion is repairable by a certified welder. $750.00 Corvette 1968/1969 Front Fender lower (behind fender opening) panels with the 4 louvre openings. These parts were originally purchased to change a later model Corvette to a 68 or 69. These are used parts and are in very nice condition. Also included are the front grilles with turn signals and harnesses along with re-pop chrome grille moldings. $450.00 Pictures are available upon request. Contact Gary Merrick either thru the private message system on this site or call 33zero-two 1 9 - four 738 Last edited by Gary Merrick; 03-22-2020 at 07:04 AM. Reason: Headers are SOLD |
Guest
Posts: n/a
Pm sent
