Old 03-10-2020, 07:19 PM   #1
Rose Racing
Rose Racing's Avatar
Liked 227 Times in 74 Posts
Default Calvert split mono leaf springs?
Anybody use the Calvert Split mono leaf springs? How much better are they than stock? What are the advantages? thanks
Rose Racing is offline   Reply With Quote
Old 03-10-2020, 08:53 PM   #2
B Parker
Liked 2,343 Times in 465 Posts
Default Re: Calvert split mono leaf springs?
Looks like you need to get to a race and check out most of the leaf spring stockers. Who doesn't use them. BP
Old 03-10-2020, 09:21 PM   #3
Gmirza
Liked 253 Times in 95 Posts
If you plan on using Caltracs they are what you want to use. You can get them in different ride heights. They are designed to work with the Caltrac bars, other springs may create a bind in the suspension. I put this setup on my car last season and the Workmanship was excellent. There is a bunch of adjustability in them, so it may take a while to get the most out of them. Probably the best bolt on leaf spring suspension ever made.
George Mirza
D/SA 1236
‘71 Duster 340
Gmirza is offline   Reply With Quote
Old 03-10-2020, 09:32 PM   #4
bykr
Liked 167 Times in 81 Posts
Lighter than stock and adjustable ride height with different rear sections
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 03-10-2020, 11:17 PM   #5
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
I have Calvert springs and CalTracs on my 68 Mustang. It was originally street legal and towed a teardrop trailer to the track each weekend. Worked on the track and tolerable on the road. A leaf spring car without Calverts is an odd bird these days. Match them with Caltracs or they will wrap up on you. Get your pinion angle right, too. I messed mine up and tried running shims to correct it. The reduced contact between the centering stud and spring caused it to start to separate and move the right rear wheel. A sharp eyed tech caught it in the waterbox before I cut a tire.
Dale Shearon
68 Mustang 6394
Old 03-11-2020, 08:18 AM   #6
Liked 10,965 Times in 2,260 Posts
Its been a long time but the Calvert springs reduced un-sprung weight by about 40#. The rear segment if fairly easy to adjust to change ride height.
Old 03-14-2020, 01:50 PM   #7
moparpilot
Liked 19 Times in 11 Posts
can`t beat them
moparpilot is offline   Reply With Quote
Old 03-15-2020, 08:21 AM   #8
larrylomascolo
Liked 77 Times in 31 Posts
X100
Old 03-15-2020, 12:24 PM   #9
They are a fine product, no doubt. Also, a great company to deal with.
In my mind though, which runs contrary to a lot of folks here, is do I really need them, and should I put together something of my own, and should I spend the money elsewhere on my combination, which is a _________________?
Old 03-15-2020, 01:41 PM   #10
Rose Racing
Exactly why I made this thread they are not cheap and I wonder if the money would be more wisely spent elsewhere....
