Liked 72 Times in 36 Posts
How does one check solenoids if they don't have a factory computer? Someone told me that's how you check them. Or do you just buy new ones Thank You Kenney Kelley
Liked 237 Times in 126 Posts
You mean the transbrake one? Internal or external? A transbrake solinoid is basically an electromagnetic switch. Give it power and ground. If it clicks it's OK. If not Not.
Liked 133 Times in 76 Posts
You can use a wiring diagram and go to the connector at the trans or you can pull the pan to access them. Then you can use an ohm meter and or run jumpers to see if they activate, you can hear them click. Now that will check the solenoid but you won't know if there is a problem in controls or wiring.
Liked 239 Times in 114 Posts
It depends what type of solenoid you have , Some solenoids are on/off valves , some regulate a pressure , and most external trans brake solenoids provide a force on a valve . The on/off and trans brake solenoids can usually be checked by just energizing them with 12 volts. The solenoids that regulate a pressure need a voltage source that cycles on and off at a given HZ but gives you the ability to control the time its off verses the time its on . Do you know what type of solenoid you have , or what its used to control ?
#5 | |
Liked 397 Times in 153 Posts
I thought there weren't any solenoids in a T-350? Something I am missing? I know I'm a polock, but still.
Phil Molski PMR Performance S/C 1623 |
Sounds like your trans has a aftermarket "E" valve body . The type of solenoids used in this type of racing vb are the on/off type .
Did it shift at all or just stay in one gear ? Does the car have an e shift controller like the one Turbo Action sells ? |
Yes it does. He brought it back to the trailer we put it up on jack stands and it wouldn't shift. I also checked the fluid level and it was ok after that we loaded it up and headed home. We got a few other things going on so I haven't pulled the car out of the trailer yet. I got a truck on the lift right now that's my daily driver so that takes precedence. Kenney Kelley
We were able to find the problem to the reason why the 350 transmission wouldn't shift at Gainesville. I called Dave at Pro Trans and he helped me in finding the problem the transmission checked out OK. My brother called Paul at Turbo-Action and sent him the E-Shift Box and Paul checked the box out and found there to be a problem with it so Paul let my brother use his spare till he could get one. I want to thank Dave and Paul both for going out of their way to help us Thank You. Kenney
