Old 03-27-2020, 06:52 PM   #1
House of Darts
Liked 20 Times in 15 Posts
Default Factory efi
Might take a crack at racing a Ford 4.6 in stock . Do I keep the factory EFI set up or is there an aftermarket unit? Change out the computer from the factory unit with what? I've seen the set ups with the FS cars and I don't think I can use this stuff.
House of Darts is offline   Reply With Quote
Old 03-27-2020, 10:44 PM   #2
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: Factory efi
Reading rules regarding my ImpalaSS you run the existing EFI.
Nothing wrong with it..Lot of good ODB2 tunes to make it run.
In fact run as light as a P/SA car...give Mike E in his Caprice a tough run.
If you build it..want a heads up run against my Pure Stocker ;-)
Bet you a whole $1 and dinner..
Old 03-28-2020, 03:37 PM   #3
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
You can use the stock computer with a TwEECer.
www.tweecer.com
Dave Noll, EF/S ,?/SA 6526
Old 03-28-2020, 05:38 PM   #4
GUMP
Liked 2,354 Times in 554 Posts
Save yourself a ton of grief, switch to an aftermarket system. It will pay dividends in the long run.
Old 03-29-2020, 10:58 AM   #5
Ed Wright
Ed Wright's Avatar
Originally Posted by gump View Post
save yourself a ton of grief, switch to an aftermarket system. It will pay dividends in the long run.
fast xfi!
Ed Wright 4156 SS/JA
Old 03-29-2020, 11:43 AM   #6
GUMP
Originally Posted by ed wright View Post
fast xfi!
Holley EFI!!
Old 03-29-2020, 03:08 PM   #7
Ed Wright
Ed Wright's Avatar
Originally Posted by GUMP View Post
Holley EFI!!
I have tuned several with both FAST XFI & Holley. I would certainly disagree. I can & do make the FAST system do things the Holley can not. Besides the Holley ECU failures I have seen.
Old 03-29-2020, 09:20 PM   #8
GUMP
I have five cars running Holley. I have never had one issue.
Old 03-30-2020, 08:24 AM   #9
Rob Wright
Liked 21 Times in 7 Posts
Can you give specific examples, and describe the impact of those things?
Rob Wright is offline   Reply With Quote
Old 03-30-2020, 08:59 AM   #10
Rsmith38
Liked 28 Times in 15 Posts
While I only have 1 jeep running the Fast XFI2, I am quite happy with it. Bought used on EBAY - (replacing the obsolete silver FAST - no longer supported). It is still a work in progress - not a lot of Jeep 4.0 support (on anything!) but no tech problems at all over 2 years.
1051 StK
Rsmith38 is offline   Reply With Quote
