#21 |
Liked 1,578 Times in 581 Posts
Yep. It is called "Core Shift". Caused by a deviation during the casting process due setting on the mold, mold alignment issues, mold temperatures and pressure differentials. One of the many reasons why the fast guys spend lots of money testing and going through many castings.
#22 |
Liked 99 Times in 49 Posts
#23 |
Liked 10,687 Times in 2,225 Posts
After winning Atlanta in the truck, a dime rocket then, I took most of my winnings and purchased a 600 bench, Flo Com,and B'ski fixtures. It still provides hours of fun.
#24 |
Liked 36 Times in 11 Posts
A veteran racer told me long time ago, you can build your own stuff, but when you want to go fast you take it to reputable shop. By the time you go all over the place getting parts and machine work you will spend as much or more. A good builder with fast customers knows what you need or where to find it. Plus their advice and experience will avoid mistakes so you can be fast.
#25 | |
Liked 799 Times in 236 Posts
And if that means you're not the killer azz kicker in your class, so be it. You can be a player by watching the qualifying sheets and being careful. And if you get a heads-up at some point...hey, the fast guy still has to run the race and turn on the win light first. Lots of things can, and do, happen. Don't let not wanting to spend a fortune deter you from getting into Stock or Super Stock. It's a lot of fun, believe me! ![]()
"That'll never work....." |
#26 | |
Thanks for editing your original post to clarify. Makes more sense to me, now. ![]()
#27 | |
Liked 225 Times in 136 Posts
Main issue is the pins and bushings on the cope and drag wearing overe the course of production. The foundries don’t pay close attention to this! Been in many foundries and they all have same problem from time to time. Lack of good QC.
#28 |
Liked 309 Times in 88 Posts
I'm pretty sure if you spend $6000 on a set of small block iron heads that "core shift" becomes a non-issue.
#29 |
Oh but you can have problems. It’s call the lawn sprinkler problems
#30 | |
Liked 2,482 Times in 697 Posts
Just my .02 Your mileage may vary.
