Is there anyone running Calverts with SS springs? For years been told you can’t run the two together. Figured I’d ask the pros.
Liked 67 Times in 27 Posts
I ran them on my 68 GTX for a couple of years. When I put the split leaf Caltrac springs on I picked up .03-.05 in sixty foot times and got rid of my spinning issues. My car would pull the wheels about a foot then spin the rear tires about one revolution making it drop the front and sometimes keep spinning. With the Caltrac springs I started sixty footing on the rear tires. That's my experience for what it's worth.
Dennis Breeden |
Liked 3,227 Times in 981 Posts
If you’re thinking about Calverts call John and he’ll sell you exactly what you’ll need. As Dan indicated the SS Mopar springs are just too stiff. They may provide initial hook but will try to unwind too quickly.
Liked 62 Times in 17 Posts
Since SS spring rates are different from one side to the other, I can't imagine what kind of a nightmare it would be to dial in the CalTracs and shocks.
Liked 44 Times in 26 Posts
just as a tag along . Would this also apply to mopar XHD springs , they have an extra leaf on right side .
I have been running caltracs like this for a few years , but with my big motor could this creat issues . I know my sixties are kind of slow , 1.42 best mostly 1.44 , car has run best of 10.28 mostly low/mid 10.30s Tex |
Liked 805 Times in 341 Posts
You can find folks that run the Calvert bars with the SS springs successfully but the easier path and the one with the higher probability of success would be to run the Calvert springs with the Calvert bars. At least in my opinion.
Liked 92 Times in 26 Posts
Ease the pain. weigh the rear of the vehicle as used, call Calvert , give them all the info they require, don't guess, the better the info you give the better the results. take your time , installing the new parts,check pinion angle , set shocks (Find it's happy spot) and have fun.
Great product , great company , great people to deal with. |
