Old 06-10-2020, 10:07 AM   #1
NHRA1926
NHRA1926's Avatar
Liked 232 Times in 69 Posts
Default Electric shifter
Does anyone know if there is an electric shifter system that makes the 1-2 shift electronically, but allows 2-3 shift manually? I am looking for one that works with a Turbo Action cheetah shifter for my turbo 400.
NHRA1926 is offline   Reply With Quote
Old 06-10-2020, 11:33 AM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Electric shifter
You can probably do that with an rpm controlled switch like MSD sells , or possibly ACD has something that works . This is going to be a big deal since there isn't too many options anymore to get a controller for an e-trans .
Old 06-10-2020, 12:08 PM   #3
Liked 10,836 Times in 2,252 Posts
Joel's on Joy may be able to help.
Old 06-11-2020, 12:02 PM   #4
NHRA1926
NHRA1926's Avatar
It is not an e trans issue. I'm just looking for some thing to make the 1-2 shift by rpm, then manually shift the 2-3 shift. I know there are RPM activated switches, but I'm looking for the actually mechanism that will perform the shift on the shifter itself. I thought I had heard of people using something years ago that did this function, shift 1-2 electronically, but allowed the 2-3 shift to be performed manually. Again it's a reverse pattern turbo action cheetah shifter and turbo 400 transmission.
Old 06-11-2020, 12:53 PM   #5
ss3011
ss3011's Avatar
ACD has a kit that works with a Turbo Action shifter . That's what I use on all my cars .
Old 06-11-2020, 12:53 PM   #6
Bill Grubbs
Liked 564 Times in 66 Posts
What class of car? Stock? Superstock? Bracket?
If Stock, year and model? What kind of trans did the car come with? Did the original trans shift electrically?
All of this will lead you to what is legal for use if Stock class racing. If Bracket or Superstock racing than just about anything goes.
Bill Grubbs is offline   Reply With Quote
Old 06-11-2020, 01:05 PM   #7
Jeff Stout
Liked 706 Times in 283 Posts
Any dual rpm box. Set 1-2 shift to desired rpm. Set 2-3 shift to 9999 rpm and shift manually. Will work unless you need more rpm then 9999
Old 06-18-2020, 08:21 PM   #8
Kenney Kelley
Liked 72 Times in 36 Posts
Where can someone buy that part? Thanks Kenney
Kenney Kelley is offline   Reply With Quote
Old 06-19-2020, 07:52 AM   #9
ss3011
ss3011's Avatar
Acd 610-987-8999
Old 06-19-2020, 08:33 PM   #10
SS3718
Liked 27 Times in 14 Posts
We have a quarter stick that is setup to do what you described. If interested, we would sale.
Nick
SS3718 is offline   Reply With Quote
