Old 07-30-2020, 01:53 PM   #1
Ryan Horensky
Liked 109 Times in 18 Posts
Default C-11
Has anyone had any issues with C-11 passing fuel check? I buy in sealed 5-gallon containers. Fuel passed fine at the Lebanon Valley Divisional. During the Columbus Divisional, fuel checked fine during qualifying. I had my fuel checked after 4th round of eliminations and I was told it checked good, but it's close to going on the bad side. When I asked what he meant, I was told the fuel is borderline dead. I then took the container to fuel check the next morning and was told it was no good. I then opened a sealed 5-gallon container at fuel check and had that checked. I was told the fuel out of the new sealed container was worse and did not pass. The date on the sealed container and the already open container was March 2020. I have been told the fuel has a 3 year shelf life in the sealed 5-gallon containers. Not sure how much truth there is to this? After scrambling for fuel, I ended up having to put C-25 in the car for the SportsNats. The C-25 was in a plastic jug out of a 55-Gallon drum. The C-25 passed fine. Not sure if anyone else has had similar issues with C-11?
Ryan Horensky is offline   Reply With Quote
Old 07-30-2020, 04:19 PM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 293 Times in 101 Posts
Default Re: C-11
Only time I have had any issues is if I leave fuel in the cel or plastic jug a weekl..I have had C-11 from 3 year old drum pass fine.. unless I leave in cell or plastic jug a week..
I had some test stale at Columbus too...alot of people in line with me were... I went back and put new I had just took from new drum and was good then..
Old 07-30-2020, 04:25 PM   #3
Lee Valentine
Liked 319 Times in 68 Posts
Default Re: C-11
We had a time when Bryan passed and I failed both filled with the same jug before run.
Lee Valentine 1661 STK
Old 07-30-2020, 04:29 PM   #4
Jeff Niceswanger
Liked 1,019 Times in 367 Posts
Default Re: C-11
Yep, last year, identical. VP took back 30 gallon from me and replaced it. I was told by Pete(at fuel check in div 3) that C-11 is a problem in hot muggy weather. I'm switching to 12 . Not worth the hassle
Jeff Niceswanger 3740 SS
Jeff Niceswanger is online now   Reply With Quote
Old 07-30-2020, 09:04 PM   #5
REGGIE WINKLES
Liked 39 Times in 9 Posts
Default Re: C-11
No issues with C-11 in 15 years. Always use 5 gallon pails.
Reggie Winkles 2650/Stock
REGGIE WINKLES is offline   Reply With Quote
Old 07-30-2020, 09:27 PM   #6
GTX JOHN
Liked 2,471 Times in 696 Posts
Default Re: C-11
We have some borderline at fuel check.....
Always close enough they have warned me to
replace = Not quite bad enough for a hard fail!
John Irving
741 Stock
741 Super Stock
Old 07-31-2020, 07:30 AM   #7
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
Default Re: C-11
I was told that bad C-11 was why Darrel Goheen got DQ'd at Topeka during eliminations.
He bought his in Kansas.
Pedigo Perf is offline   Reply With Quote
Old 07-31-2020, 09:37 AM   #8
Signman
Liked 269 Times in 99 Posts
Default Re: C-11
Ryan
Race fuels in general don't like being stored in hot locations like leaving it in the trailer week or more between races. Been there.
As stated it does not store at all in plastic jugs. Been there.
Race fuel does not like large changes in temp store in a cool as possible stable temp like a garage. I store it in my shop or garage, sheds can get really hot.
And this one is unavoidable it really does not like being shaken as in when traveling to and from races. Whether sealed or not.
VP themselves told me 5 gallon cans even if sealed are not 100% only drums are reliable. The crush seal around the spout is not the greatest.
Old 07-31-2020, 01:05 PM   #9
5389stk
Liked 72 Times in 6 Posts
Default Re: C-11
Watch where you buy from. Large distributors buy empty 5 gallon cans and seals and package there own out of underground tanks. You have no idea how old it is. 55 gallon drums are ok.
5389stk is offline   Reply With Quote
Old 07-31-2020, 01:36 PM   #10
superdart
Liked 65 Times in 7 Posts
Default Re: C-11
If there battery is low, it doesn’t read correctly
superdart is offline   Reply With Quote
