Liked 4,390 Times in 506 Posts
I am still having issues with erratic tach signal at high rpm in the data log and I even see it on the tach as well. My data logs have always been very choppy and jagged which makes the ECU do crazy things and even hits rev limiter which I have set very high.
I shielded my trigger wire that goes from ECU to Crane ignition box. I make sure to keep Magnecor wires away from sensor wires. Some distributor power and trigger wires DO pass by the alternator which makes me wonder if that is an issue. I have checked all grounds, made new grounds, use dielectric grease on plugs and boots, not sure what else to do. I am told it could just be the nature of a dual-sync distributor that gets its crank signal using the hall effect and harmonics involved but I would like to know which other wires may need shielding. |
Liked 162 Times in 45 Posts
I think that I would completely eliminate the alternator first. Belt off, wires off and isolated make run and see what it does. Maybe install extra grounds. Start with one from ignition box chassis to known ground. And do t trust any grounds! Us the “tug test” on every connection ground and hot. Steel wool all terminals and where they connect.
Liked 178 Times in 59 Posts
Electric fans are a good source for interference also. Separate all ignition wiring from fan wires.
Liked 1,887 Times in 579 Posts
Try a 10k ohm 1/2 watt resistor in tach wire
KEITH MAYERS 2-1/2 X somebody Still many X nobody Last edited by Keith 944; 08-15-2020 at 10:40 AM. |
Liked 931 Times in 265 Posts
I keep ignition wiring and "dirty" lines (alternator, fans & motors) separated as far apart as possible. And twist or braid the ignition trigger wires.
All grounds are connected to the ground post of the battery with copper - wires, cables. Don't rely on sheet metal. Would be interesting to see what happens if the alternator is not functioning on a pass. |
Liked 336 Times in 183 Posts
try grounding the head to the block and the block to the frame or body with the old style braided ground straps--NEVER use solid core wire for ground wire --if you do use braided wire make sure it is of sufficient gauge and not only crimped but put a bit of solder on the wire and connecter crimp area to make sure it is really grounded ---
Solder is often confused as the very best in connections, when in fact poorly solder connections are very bad. If you don’t know how and have good equipment then stick with good crimps and vigorously apply the “tug test”!
Liked 889 Times in 239 Posts
Too many devices on a common ground can lead to r/f noise .
As was mentioned the fan is the single dirtiest source on the car followed by the electric fuel pump. I use ferrite core shields on everything . I use the type with a plastic case that snaps together around the wire . Very inexpensive, available on Amazon ,EBay . The old school and still one of the best ways to find the source is to use an old cheap AM pocket radio tuned down to lowest end of the band ,around 540 . it will pick the culpret just about every time.
#9 | |
Bobby, you place them on the supply b+ wire , you can also place them over twisted pairs from the ignition triggers and the coil primary
