Old 08-30-2020, 07:39 PM   #1
scamper
Default Et genie users past and present
Hi I'm looking for some help with my new unit to try and fast track my learning a bit. I understand every car will be different biut hoping for a bit of insight. So I run a 750 with the 1 5/8 base plate,the genie is 1 3/4 would it be safe to assume that I would not see any et reduction untill the genie was closed to the 1 5/8 size? Also I don't need to kill alot maybe .2 or less what would be a big change to the genie as opposed to a small change. Is 1 turn a big change and 1 flat small, how sensitive is it? Trying to get an idea of where to start and then how big of adjustments to make after.
Thanks to all that respond.
scamper is offline   Reply With Quote
Old 08-30-2020, 10:15 PM   #2
rob7181
Default Re: Et genie users past and present
I have been using it for a couple years and love it. One turn will maybe slow you up .02. It comes with a pin dial gauge and that will help you to understand what size will slow you up how much.
rob7181 is offline   Reply With Quote
Old 09-01-2020, 06:31 AM   #3
scamper
ok thanks.any other users care to share
Old 09-03-2020, 01:30 PM   #4
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Never used a Genie but I know a couple people using plates and it seems that every .100" change in hole size would be pretty close to .10 ET on the track.
S/ST 51
S/C 53
Old 09-04-2020, 05:37 PM   #5
scamper
Smile Re: Et genie users past and present
Thanks I would think it should be apprx the same
Old 09-07-2020, 04:22 PM   #6
cad
cad's Avatar
Liked 93 Times in 52 Posts
My pit partner uses them on his sportsman bracket truck, and can dial it.
I believe Nick Siebert (Luke's brother) uses one to run super street.
Clark
