Liked 99 Times in 49 Posts
I have a 780 holley carb that has fuel coming through 1 booster, check the float change the gaskets 6 pounds of fuel pressure. the carb run fine till i put it back on the stocker motor. Changed the carb to another 780 it ran fine till i shut the motor down then restarted it ,same thing. Any guesses?
#2 | |
Liked 278 Times in 110 Posts
I did check that and also changed the float ,the old float weight 14 grams new one 15 grams. it only slubbers fue out of one booster, changed the needle and seat. I Never had this happen in 40 years of holley carbs.
Liked 48 Times in 18 Posts
Jim if you're talking about dripping after you shut the motor off you just aren't turning your fuel pump off early enough before you shut the motor off in this hot weather. If you are talking about with the engine running either your float level is too high, or your fuel pressure guage is not right
Liked 11,028 Times in 2,266 Posts
Is the mounting surface level on intake side to side?
Liked 227 Times in 138 Posts
Change both gaskets float bowl side and main body side also replace the the 4 bowl screw gaskets and torque the the bowl screws to 35 in-pounds and your problem should go away.
Liked 2 Times in 2 Posts
power valve hitting the base plate screw "boss" in the vac. chamber not allowing the m/block gasket to seal to the venturi surface. this is a common problem with "older" venturi's. check a new venturi an you'll see what i mean..
this is also made worse if you are using the new non-compressible p/valve gasket with a mill'd surface of the venturi as they become closer together. |
Liked 66 Times in 37 Posts
o ring on needle and seat
72 cutlass |
#9 | |
Banned
Liked 179 Times in 89 Posts
Also check the needle and seat, I've had debris stick in there and prevented it from sealing.
