Old 09-17-2020, 10:45 AM   #1
Andy Friar
Andy Friar's Avatar
Liked 226 Times in 76 Posts
Default Bias Ply Tire Pressure
I am looking for feedback on tire pressure and amount of 'wrap' on our tires at launch. I know people on here have more experience and I was hoping to hear what pressure other people have run bias ply tires at. We are running 14.5psi, 3600rpm launch and 30 x 9 x 15 Hoosier D05's on a 10" rim in this video. 1.55' 60 ft in this video as well while weighing in at 3440 w/ me in the driver's seat. We are only running bracket races currently, but the car is setup as a skinny tire SS car. Thanks for the help.
Andy Friar
Andy Friar is offline   Reply With Quote
Old 09-18-2020, 03:01 PM   #2
cad
cad's Avatar
Liked 93 Times in 52 Posts
Default Re: Bias Ply Tire Pressure
That looks pretty darn good. The weight of the car, how much hit, and how much hp affect it. I ran a 3055S MT on my 68 Camaro with 12 psi, and the slick always looks good in slomo.
Clark
Old 09-18-2020, 04:19 PM   #3
Joe DeMarzo
Liked 121 Times in 11 Posts
Andy., when I run the bias tire, Hoosier 30x9x15 D 05 I run minimum 18 lbs and up to 22 lbs depending on the track. Car weights 3400 plus. Looks like your climbing the tire and should pump it up 2 lbs at at a time to see what your car likes best. Good luck.
Joe DeMarzo 1317 STK
Old 09-19-2020, 10:32 AM   #4
Adger Smith
Liked 880 Times in 311 Posts
You also need to watch the surface of the tire for full contact "feather".. The tire will tell you if it is making proper full contact.
Bias tires work the sidewall. Most of the time Too little air over works sidewalls.
Somewhere I have a real good picture of a run with my car when it was killing the sidewalls from low air pressure.
Adger Smith (Former SS)
Old 09-19-2020, 04:22 PM   #5
Andy Friar
Andy Friar's Avatar
Thanks for the reply's and experience shared. Our buddy Dave has been all over us to add more air. Looks like I will this Sunday at Milan. Nostalgia Drags with Nitro Funny Cars, Gassers and 1990 and older bracket racing. Should be a good time!
Andy Friar
Old 09-20-2020, 07:54 PM   #6
HR9121
HR9121's Avatar
I'm with Joe I normally would run 18 to 22 psi and have ran it at 24 before. My car most races at 3650 and sixties around 1.47 Like Joe said keep adding in 2 pound increments until you find the sweet place.
James Williamson
W200 J/SA. SS/JA
Old 09-29-2020, 09:30 AM   #7
Andy Friar
Andy Friar's Avatar
Update. I went to Milan on Sunday (9-27-20) and bumped the tire pressure up 2# to 16.5 for the one and only time run I got. Car launched hard and the 1/8th picked up .02 and 1mph from previous runs in similar air for my Dad. I ran my best et and mph ever with the car. 11.20 @ 119.75 mph @ 1950 DA. Video looked good too. Below is a still of the difference from the 14.5 and 16.5psi launches at the same 3600 rpm and all other aspects of the car being the same. Dad is racing Friday night at Milan in Open Comp and we are going to push him to put 18.5 psi in the tires for Q1.
Open Comp is a .500 PRO tree, qualifying on reaction time class w/ no dragsters or delay boxes. Your dial-in all night is .10 faster than your best Qualifying ET. 56 car field and I have seen as many as 89 cars trying to qualify with the bump being as low as .039 RT! Lots of whomping at the stripe and brake lights too. Dad is tied for 10th in points, which is pretty darn cool.
Youtube link of TT1 from Sunday. Full speed and then slo-mo:
Name:	Chevelle Tire Pressure Comparison, 9-29-20, 1000p.JPG
Andy Friar
Old 09-30-2020, 06:24 AM   #8
Andy Friar
Andy Friar's Avatar
For reference and because I like seeing numbers and data, here is the corner weights of the car prior to installing the Qa1 Rear Upper control relocation kit at the diff. Other reference items to note. Car as weighed this day and as we race it now has 4 wheel iron drums, Diehard big battery in the stock RF location and the car does not have any ballast bars or boxes in it. 10 gal alum fuel cell in the middle and rear of the trunk. Memory was about 7-8 gals in the cell when we weighed it. Kirkey seats, no rear seat.
DVD players in the headrests, 12" sub box in the trunk and R12 a/c too (all kidding...)
Name:	7-14-20 Corner Weights.JPG
Andy Friar
Old 09-30-2020, 05:44 PM   #9
L.Fite
Liked 498 Times in 244 Posts
Well... my two centavos...
Air 'em up 1/2 lb. at a time 'till the 60 ft. falls off, then back up 1/4 lb.
I'm a dinosaur... but that's how we did it back in the stone age...
Your mileage may vary.
L.Fite is offline   Reply With Quote
Old 09-30-2020, 06:05 PM   #10
Andy Friar
Andy Friar's Avatar
Thanks for the insight and that is a solid approach. The car was designed 10 years before I was born and I am 41 now. Dinosaur approaches are valid...
Andy Friar
