Old 09-25-2020, 03:39 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default question, G body 7.5 rear life
In a G body stocker weighing about 3200 with a 305 stocker package, running low 12's high 11's
Will the 7.5 gear give any service life?
Larry Woodfin 471W
Old 09-25-2020, 05:50 PM   #2
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Default Re: question, G body 7.5 rear life
50ft or 50 seconds which ever comes first! Spend the money once and put in a 12 bolt. Several manufactures offer a complete bolt in.
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 09-25-2020, 05:54 PM   #3
Brian Fink
Liked 28 Times in 9 Posts
If you are making decent horsepower and the suspension is up to the job,the 7.5 won't hold up. I thought a Grand National 8.5 would do the trick ;that piece failed after a few seasons .The answer is to do it right the first time with a 12 bolt and pro gears.
Brian Fink is offline   Reply With Quote
Old 09-25-2020, 08:12 PM   #4
Jeff Stout
Liked 706 Times in 283 Posts
Yes to all above. Had a Firebird. It ran 13.60 and boom oatmeal in the rear end housing
Old 09-25-2020, 08:15 PM   #5
CMcAllister
Liked 920 Times in 259 Posts
Axles and internal parts are all about the same money, save for the extra cost of pro gears. Put the best unit in it that you can from the beginning.
CMcAllister is online now   Reply With Quote
Old 09-25-2020, 08:49 PM   #6
Ralph A Powell
Liked 226 Times in 137 Posts
Oldsmobile had a bolt in 12 for the G-boy racers. There are a few around if you know where to look.
Old 09-25-2020, 10:06 PM   #7
Liked 5,147 Times in 1,964 Posts
I give up ... Where do you look?
Old 09-25-2020, 10:28 PM   #8
Jeff Stout
News to me. Any more details?
Old 09-25-2020, 11:56 PM   #9
SSDiv6
None of the factory issued Oldsmobile Stock Eliminator cars had 12-Bolts in the cars. They all had 8.5 rear ends. Later on, a few switched to aftermarket 12-Bolt rear ends.
Old 09-25-2020, 11:58 PM   #10
SSDiv6
Find a 8.5 from a Grand National or 1984 to 1987 Olds 442 or an aftermarket 12-Bolt.
