#11 |
Liked 358 Times in 83 Posts
Does anybody REALLY think that in these COVID times, there will ever be teardowns, as we all knew them? Hell, there isn't even tech inspection anymore. You write what you want your car to be on your tech card, and your wish is granted. I'm waiting for the first guy to show up with a big-block, claiming it's a 283.
#12 |
Liked 310 Times in 104 Posts
The 170 cc intake could be reduced enough for most small block stockers..
the 185 not so much Last edited by Mike Taylor 3601; 10-01-2020 at 11:05 AM. |
#13 |
Liked 66 Times in 37 Posts
Can I get the number for the 170 heads. My heads are 168cc. Thanks
72 cutlass |
#14 | |
James Schaechter 3163 STK |
#15 | |
Liked 800 Times in 237 Posts
However, as supplied by Edelbrock, they are 185 cc intake ports.
"That'll never work....." |
#16 |
172 is for SS. Stock is same as factory.
72 cutlass |
#17 |
Liked 127 Times in 49 Posts
Dart is the same way. I ordered a set and they were 180cc. I called Dart and talked to their quality control and was told that the tooling has been worn making the runners larger than advertised. I do know if you find an original older set they do match up to NHRA's specs.
Bobby Lundholm 3516 G/SA |
#18 |
