#11 | |
Liked 225 Times in 136 Posts
Where are they today God only knows. A lot of the racers got 2. You just going to contact old Olds racers and see if they might have stashed one! |
#12 |
Liked 719 Times in 220 Posts
Seems to me that the 7.5" rear end was a V-6 rear end that came out in the mid '70's when everything got downsized and cheapened to the point of near extinction. The 8.5" rear end came along in the 72 model year in a few cars, it replaced the 8.2" 10 bolt and the 12 bolt, but by '73 or so, nothing made enough horsepower to break it anyway. The 8.5 would probably hold up if you put steel web caps in it, the right hardness gears, of which there are not anywhere near the ratios available that the 12 bolt has to offer, a good spool, proper axles, and by the time you did this, you might as well have bought an aftermarket 12 bolt housing that's right for the car. This is a clear cut case of paying to do it right and paying only once. The Buick GranSport turbo cars had the 8.5, but the turbo cars didn't leave nearly as hard as a small block stocker will, they made up for it with boost down the track a ways.
#13 |
Liked 33 Times in 17 Posts
Finding a Grand National housing is proving to be rather difficult. I know because i am looking for one to put in a Malibu Wagon.
#14 | |
#15 |
Liked 880 Times in 311 Posts
Back in the IHRA days I had a customer that ran a Crate 385 in a Malibu wagon. The 7.5 would last about 50-70 runs and spit out the pinion or take teeth off the ring gear. That was with a good spool, caps and axels. Went to the 8.5 and the ring and pinion problems stopped. As a by product he was able to get better brakes on it, too.
Adger Smith (Former SS) |
#16 |
https://gbodyforum.com/threads/86-44...ear-end.79216/
This is not my diff. I have had good luck sourcing parts from car specific forums. 1500 US seems high but that may be the current rate. |
#17 |
Liked 997 Times in 201 Posts
Isn't a 7.5 rear end the same rear end they put in Vegas in the 70s?
#18 |
Liked 71 Times in 23 Posts
Friend of mine has a 87 Grand National rear end for sale, 3.90 gear TA Cover, stock axles, good drum brakes. He is In Illinois, but will be going to SGMP in a couple weeks for ducks race. He can deliver between Illinois and SGMP $1,600 obo
Monte Howard 3209 STK, 3208 SS |
#19 |
Man,I hope not! In the 70's when I worked on the line at the Chevy dealer, the Vega had a ring and pinion pitch noise(howl) at about 30-35 MPH. You could adjust pinion depth, experiment with back lash, do whatever you want, but that rear end was going to howl. We were so glad as more and more Vegas went beyond warranty because we knew people weren't going to spend money on a Vega to fix it. We never really came up with a real fix for that unit, it just seemed to be a real poorly machined piece. Quality control was nonexistent anyway on those cars. Also, when the Chevette came out in 1976, every last one you would ever drive had a pitch noise that would come in at 40 MPH. You didn't need the speedometer to tell when you hit 40, the rear axle assembly would tell you. Also, full sized vans did that, too, although trucks wouldn't even though they had the same rear end assembly. Later on, it dawned on some of us that the Vega, the vans and the Chevette all were unit body with the rear end bolted to a unit body. It was possible that setup transmitted a normal noise to the passenger compartment that the separate frame and body with mounting bushings somehow isolated it. I was nervous about smaller rear ends not only from the strength standpoint, but wondered if the noise came from poorly machined or mismatched parts somehow.
#20 |
Liked 450 Times in 133 Posts
You are right Greg the G Vans were horrible with rear end howling new or used years ago ive had race car rear ends that didnt howl as bad as them. going back to the original question go ahead and buy the good stuff now for a 12 bolt and then no worries.
Jerry Retired 3490 3492 STK SS SST Last edited by Jerry Terry; 10-05-2020 at 03:29 PM. Reason: add |
