Liked 170 Times in 56 Posts
Having issues with steering boxes on a 67 Camaro, been through a couple reman boxes it seams after a couple seasons they are worn and have lots of play. Guessing wheel stands are hard on them. Any recommendations on a quality unit?
Liked 1,948 Times in 589 Posts
I bought a new Vega. Box from either Jegs or Summit. No issues with that except the 3 bolts in the top came loose. Gives a bit more header clearance on that side. Check your bump steer. If that is out of whack it will put stress on the steering system. I put a bump steer kit on mine and it is with in 1/4 inch through the entire travel.
Mike Pearson 2485 SS Last edited by Mike Pearson; 11-13-2020 at 09:35 PM. |
Liked 172 Times in 46 Posts
I contacted Bob Blackwell about changing my box out to a Vega style box and was told not legal in Stock per Wesley.
Dirk A/S 5036
Dirk Olson 5036 STK Last edited by Dirk Olson; 11-14-2020 at 11:30 AM. Reason: spelling |
Liked 62 Times in 23 Posts
You can rebuild these boxes easily, Midwest Directional Services offers a rebuild kit #RK550, 816 796 6400. It consists of brg. races, bsg. and seal, no special tools needed. Make sure worm and sector gears not worn.
One of the best in the country is Redhead Steering in Seattle, Washington.
They rebuild and improve old steering boxes and make them better than new. https://redheadsteeringgears.com/ |
Liked 293 Times in 65 Posts
I recently found a brand new (NOT remanufactured) box for my '66 Nova, made by a company called Lares Mfg in Minnesota. They're sold through Rock Auto...I just now looked up 1967 Camaro and they make them for those, also. I opted for the fast-ratio 16:1 manual box. Haven't installed it yet, so I don't have any feedback on how well it works, but it's got to be better than the 54-year old original. Oh, and they're very reasonably priced too! Around $250.
Liked 880 Times in 311 Posts
,Larry & FED gave me these a while back.. hope it helps
Adger you have several choices. * S-10 manual box [with the S-10 box in most cases it is a direct replacement. Input spline & pitman spline same as OE. It will have a four bolt top] * manual GM box from 70's cars [this is also a direct fit in some cases. GM produced several spline counts so it takes some comparing to find the exact match. This is a three bolt top. This box is about one pound lighter than the S-10 box and overall slightly smaller. * Vega box [this box is smaller and lighter than both the above, however, it requires a custom/special pitman arm. Ed Quay, Flaming River, and maybe others furnish the special arm. Of the three, I would look for the 70's box. __________________ Larry Woodfin, GT Super 10 Adger, I "think" all GM manual boxes will be about the same in ratio. [maybe an exception but it would be a rare option] The greater turn to turn ratio of manual boxes is an advantage, steering is not touchy] The 60's and 70's three-bolt top gear is a good choice but it takes careful searching to find the correct spline count. They are out there, I have found and installed several. An S-10 box is available reman from most parts stores. To my knowledge, there is only one part number. It's advantage, a direct bolt in replacement, remove power gear, install S-10 manual gear. The quicker ratios come with PS boxes. __________________ Larry Woodfin, GT Super 10 471W VIP Member Join Date: Jun 2006 Posts: 2,786 Re: 3rd Gen F Body Steering box ________________________________________ I have a Chevy book (from GM ) 1984 that lists 2 Manual steering gear assemblies 7806396-------20:1 ratio---- 67-75 Camaro 7819935-------16:1 ratio---- Monza and Vega FED 387
Adger Smith (Former SS) Last edited by Adger Smith; 11-20-2020 at 03:16 AM. Reason: sp |
Liked 269 Times in 99 Posts
If you fell the wheel stand is the issue install a damper. It is a safety item and should be allowed based on that alone.
