Old 11-25-2020, 06:48 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default engine heater
I have looked at the elements that bolt in a core plug hole but I do not like the fit. What other options are available?
I "think" I want a heater that will install inline the lower hose.
Larry Woodfin 471W
Old 11-25-2020, 07:20 PM   #2
SSDiv6
Default Re: engine heater
Not required, but if you insist to use one, put the heater on the oil pan and not the cooling system and only use it at the start of the day. It takes longer for oil to heat up than water.
https://rehermorrison.com/tech-talk-25/
Old 11-25-2020, 07:28 PM   #3
Dragsinger
I have looked at those. Do you have a brand and size, and wattage suggestion? How long does it take to achieve 130 degrees or so?
Larry Woodfin 471W
Old 11-25-2020, 07:39 PM   #4
John Kissel
Liked 230 Times in 94 Posts
I bought one from NAPA around 16yrs. ago that goes in the lower hose of my '67 FireBird. I think it is made by Everhot. I cover the front of the radiator with a big towel to help keep the heat in. It takes a while to heat up the engine as I have a big BeeCool Radiator. I'll go look tomorrow for the wattage.
John Kissel is offline   Reply With Quote
Old 11-25-2020, 08:58 PM   #5
FED 387
Liked 333 Times in 180 Posts
Larry-- check your PM --Dick
Old 11-25-2020, 09:43 PM   #6
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
These are the folks who make the "Zerostart" heater systems, both tank and silicone-pad style (like the Moroso unit). Hopefully some helpful information for you on wattage and capabilities.
https://phillipsandtemro.com/
Lew Silverman #2070
"The Wagon Master" N/SA
Old 11-26-2020, 12:06 AM   #7
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
I've got 3 of the magnetic heaters usually for winter use that I usually use. (Theres always people driving all over the pits "warming up", it made me think that's a lot of expensive gas not accomplishing much. I've also been told that I squeak when I walk ). One 300 watt & two of the 200 watt units. I put 2 on the engine oil pan and the last one on the rear end housing. I just use 1 back there because I use Redline Super lite shockproof. Of course I can't use this on the Escort. I know theres the glue on blanket style but I've heard the adhesive isn't very good. Would be interested to hear other's experiences there.
Dave Noll, EF/S ,?/SA 6526
Old 11-26-2020, 09:37 AM   #8
John Kissel
I could not get to the front of the car as the snowblower and other stuff is in the way.Both NAPA and Tractor Supply have engine and oil pan heaters made by Katz and work great..The engine heater from T.S. is directional, does a good job for old style '99 Suburban.
Old 11-26-2020, 09:44 AM   #9
Rsmith38
Liked 28 Times in 15 Posts
I had the Moroso stick on on the bottom of the oil pan. Worked well for 10 years - finally quit. Check Google for pan heaters - us Northerners use several types that are available. Also had a freeze plug heater that was optional on my daily driver Jeep. Never had a problem.
Rsmith38 is offline   Reply With Quote
Old 11-26-2020, 11:02 AM   #10
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
I have these Zerostart/Wolverine heaters on the oil pan and transmission pan, can warm things up pretty quickly. Pretty sure this is the size I have on the oil pan, but the transmission one may be slightly larger. The offer a ton of shapes/sizes
https://www.amazon.com/Zerostart-340...6402804&sr=8-1
3207 D/SA, C/ED
Andrew Hill is offline   Reply With Quote
