#41 |
Velocity is your friend.
#42 | |
Having the baseline number from the intake allowed me to then work on the heads, knowing the Delta the intake would effect on the cylinder heads. The brand of valves makes a difference the same as the cut and angles. |
#44 |
Liked 2 Times in 1 Post
I don't know how much of their experience comes from working w/ lower-lift Stocker heads, but cylinder head guys like Darin Morgan and Chad Speier emphasize port designs that remain stable w/o any backing up in flow at lifts well above the actual valve lift used, even if it reduces some of the flow #s seen at lower lifts.
However, those recommendations are when they're talking about ports remaining stable to 1.0" when the valve lift might be .700". They're saying this, IIRC, based on findings from flow testing well above the standard 28" H2O pressure since the higher test depressions can reveal different flow behavior than seen at 28". How that might need to be "adjusted" (as much as can be w/in the constraints of the class guidelines) when the peak lift is .400"-.500", I dunno... just throwing that out there for consideration. Thx |
#45 | |
By the way, Darin's stepdad was Kip Martin and he got his feet wet with him doing Stock and Super Stock heads. Chad has been doing cylinder heads most of his life and worked at Patterson and MadCap racing engines along with Nick Ferri.. Chad is still doing Super Stock cylinder heads, both cast iron and aluminum. |
#46 |
One reality to deal with is that there are lots of cylinder heads that have been maximized and the guys that build them, charge accordingly based on the R&D and time they put behind them.
Too many times there is no other option than to pay the money if you want to go fast. The other option is to do it yourself, which entails a big learning curve, asking the right people that are willing to share and investing on the right tools and equipment and at the end, entails lots of money too. |
#47 |
Liked 99 Times in 49 Posts
What i know about head flow, the earliest flow number for a 441 chevy .Was 165 cfm the last set i worked on was 235,this was at 28" at 450 lift. was about 35 hun.
#48 |
Gee, I wonder how that happened! They must have improved the flow benches. They couldn't possibly have done anything to the cylinder head, that wouldn't be legal.
#49 |
Liked 706 Times in 283 Posts
