Old 02-09-2021, 06:19 PM   #1
John Beasaw III
Liked 2 Times in 2 Posts
Default Dumb question... +/- .015 on crankshaft
Ok dumb question, how much power is there in having the crank machined +.015 on a sbc. Is it actually worth the expense? Is there another purpose for this other than added stroke?
Thanks,
John Beasaw
John Beasaw III is offline   Reply With Quote
Old 02-09-2021, 06:28 PM   #2
Race Wife
Liked 13 Times in 2 Posts
Default Re: Dumb question... +/- .015 on crankshaft
Yes.
Race Wife is offline   Reply With Quote
Old 02-09-2021, 06:37 PM   #3
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
If you are making 1.5 HP per cubic inch, in theory you add 1.5 HP for every cubic inch you add.
A correctly stroked crankshaft will also correct a poorly indexed crankshaft.
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 02-09-2021, 07:24 PM   #4
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
I personally have found cubic inch to be worth nothing with induction, comp, and cam being the same in a modest bracket race situation.
Old 02-09-2021, 09:01 PM   #5
MR DERBY CITY
Liked 8,131 Times in 1,535 Posts
Thanks,
John Beasaw
It depends, if you want to run with the BIG DOGS, ...you can’t leave ANYTHING on the table.....
Old 02-09-2021, 09:34 PM   #6
GUMP
Liked 2,361 Times in 558 Posts
It's the thing you do when you want that "LAST" little bit......
GUMP is online now   Reply With Quote
Old 02-09-2021, 11:06 PM   #7
GTX JOHN
On a Stock or SS we always run .013 stroked crank.
Has to be indexed anyway at least with all our Mopars
I have seen 10 stockers in class within less than a Tenth
of a second
One year in Class in Denver Natl's = we had a race decided
by .0001
Plenty of Class racing with an hundred or two!
John Irving
741 Stock
741 Super Stock
Old 02-10-2021, 04:25 PM   #8
Jim Kaekel
Liked 535 Times in 110 Posts
Dean is correct, you're effectively killing two birds with a single stone!
Jim Kaekel 3836 STK
Old 02-10-2021, 08:18 PM   #9
Liked 10,850 Times in 2,254 Posts
Adjusting stroke will not correct index. To fix index try to find a grinder, machine, with new or rebuilt chucks that has index stops at 90*. After its index always check TDC and zero on damper. Rolling the crank to get it to "clean up" @ .020" under while stroking it .014" will some time change the relationship between the two. To check quick index #1 and #6 should arrive at TDC at the same time using two dial indicators.
We use to grind cranks for Kuntz & Craft years ago. In fact we have lost to a 428 heads up with a crank we stoked and indexed for Jim and Keith.
Old 02-10-2021, 08:51 PM   #10
John Beasaw III
Thanks for the insight. I knew the rules allowed indexing/stroking, i just wasn't sure if there was a large enough advantage vs expense.
As for my combination i don't have a budget to run with the big dogs. Game plan is .40-.50 under in the heat just to play.
Thanks
John Beasaw
