#11 | |
Liked 5,120 Times in 1,951 Posts
Joe C. , who claims to be a sportsman racer, said they were checking the dial -ins , but that didn't appear to be the case, from my vantage point.
#12 |
Liked 800 Times in 337 Posts
Asking for myself, not a friend...
My question would be if I accidentally deep stage can I backup and light the pre-stage again? What if I back all the way out and come back in? Bill |
#13 |
Liked 136 Times in 49 Posts
The way I read it. It says the stage light so you would need to go all the way thru Pre-stage and Stage to get disqualified and not allowed to back up and restage.
As far as if you accidently went deep in a class where it is not allowed but did not go thru the stage light. Can you back up I think that needs to be clarified by the powers that be. I would think as long as you get backed up before your competitor gets staged you may be ok. But that is just an opinion. It also says when in the stage process so I would think if you crossed in the process of doing the burn out that would not effect this rule. It may get you tossed if your class does not allow burning out across the starting line. But this rule shouldn't effect that. |
#14 | |
At least that's how it used to be. Now? Have to call my lawyer for an interpretation.
#15 |
Liked 135 Times in 74 Posts
I would not be surprised it is some type of new technique. The latest staging I have seen racers do in the big dollar brackets races with dragsters, after burn out, backing up, they stop at prestage and leave prestage on, awaiting for other driver to prestage.
#16 |
Liked 1,341 Times in 408 Posts
another first round in super stock there was a crew member standing in the stage beam while the other car was pre-staged. The starter had to run out and get the person out of the lights.
#17 |
Liked 309 Times in 88 Posts
In the early days of super gas some of the drivers had a indexed magnetic tape on the driveshaft with a sensor sending a signal to a indicator light on the dash. Once they turned the bottom light they would roll in, they knew what value they needed to see on the indicator to keep from deep staging.
NHRA outlawed these devices probably 25-30 years ago. |
#18 | |
#19 |
Question..Race Pack type onboard loggers use a driveshaft counter /reader, right? And lots of new cars have digital dashes, right? Turn the key off and they go blank, right?
Ah, never mind..This is silly
#20 |
Liked 2,483 Times in 697 Posts
[QUOTE=GTS340;634165]Sounds like to me another way to cheat. Getting a 1320 measurement somehow. I mentioned a long time ago about racing a world champ that only stared at the tach like it was a geiger counter. Burp burp burp right on the dial in a head wind. Jumped out the car and tells his crew "I thought I turned the tire." Nice![/QUOTE
Perhaps not even very long ago? That is all I will say!
