Old 02-17-2021, 06:34 PM   #1
Jeff Stout
Liked 706 Times in 283 Posts
Default Micro Polishing Crank ?
Legal to do in stock and any HP benefits? Company in AZ just started up.
Old 02-17-2021, 08:30 PM   #2
GTX JOHN
Default Re: Micro Polishing Crank ?
We have done so for 40 years.
I would not think much if any HP benefit you can find.
It might help bearing life a bit.
It can not hurt to at least to use a worn belt and shine it
up the best you can = without removing much metal.
John Irving
741 Stock
741 Super Stock
Old 02-17-2021, 08:32 PM   #3
SSDiv6
Liked 1,604 Times in 583 Posts
It depends. If they are doing the Micronite or the Omicron finish like Shaftech does, on the whole crankshaft, it is not legal in regular Stock.
Yes, there may be some power because it sheds the oil off the crankshaft. When it is allowed by the class rules, I use the Omicron finish from Shaftech. When I take the engines apart that have the finish, they are almost dry because the oil does not adhere.
This is the way a crankshaft with the Omicron or Micronite finish looks.
Old 02-17-2021, 08:40 PM   #4
bry-war
Liked 2 Times in 2 Posts
Brings up a good point. With sufficient quality oil the parts do not touch anyway.....we hope. I have experience with an alky fc where we missed the tune and could “mash” a bearing .060” wider at the bottom of the bearing than its stock width measure at the parting line without blackening them. Hence the oil never gave up doing its job and working overtime. If anything,
polishing gives you justification of cost when it’s prettier. BTW: I don’t miss 60 and 70wt oil in my hair between rounds.
bry-war is offline   Reply With Quote
Old 02-17-2021, 08:51 PM   #5
SSDiv6
You are correct about the bearing journals; they operate on a hydrodynamic film of oil and should never touch.
The Micronite and Omicron surface finish helps the rough surfaces of the crankshaft, making them smoother and polished. The process consists of placing the part in a vibratory tumbler, with a specific media and run it for a specific amount of time. It also helps camshafts, lifters, connecting rods, valve retainers and valve springs.
Old 02-17-2021, 09:29 PM   #6
Steve OB
Steve OB's Avatar
Send a message via Yahoo to Steve OB
Out of curiosity, what is a ballpark cost to have a crank done with the Omicron or Micronite finish? A non aftermarket crank.
Steve Obertanec
Steve OB is offline   Reply With Quote
Old 02-17-2021, 09:52 PM   #7
SSDiv6
Speak to Nick Boes at Shaftech - (419) 423-1000
