#121 | |
Liked 354 Times in 120 Posts
PRODUCT DESCRIPTION Accufab c75-2 - Accufab 75mm Camaro LS1 Throttle Body 1999.5 - V8; 1999-2002. Accufab 75mm F-Body LS1 Throttle Body 19991/2 & Up ABOUT ACCUFAB History and information about Accufab and their products. ACCUFAB racing was founded in 1993 and has a long history in the performance car parts arena. ACCUFAB designs parts with quality in mind not quantity in mind. Whether you are buying parts for your street machine or racing car ACCUFAB from LMPerformance has the parts for you. LMPerformance is proud to offer ACCUFAB THROTTLE BODIES and Plenum for your Chevy Camaro or Corvette, Dodge, Ford Mustang or F-150, and Pontiac GTO. You can't go wrong with an ACCUFAB part. Get the best price on your ACCUFAB throttle body and plenum at lmperformance.com. ACCUFAB RACING has been successful over the years because the company maintains a tight control on quality since all of their products are designed and manufactured at their factory in Ontario, California and they do no outsourcing of any of their products. ACCUFAB is confident that they provide you with a preeminent product by virtue of the fact that they see to it that only premium materials are used and maintain superlative quality control standards as they feel their customers deserve only the best and they see to it that they get just that. The design and manufacture of high performance throttle bodies is at the heart of their business and there is no compromise when it comes to quality of the materials selected for the fabrication of their throttle bodies, whether it be the type of aluminum or stainless steel chosen or something as simple as brass blades and the highest quality bushings and screws, everything is top of the line with no excuses accepted for using anything less. ACCUFAB throttle bodies are machined on CNC machines from 6061-T6 aluminum billet to extremely close tolerances and the shafts are ground to perfection and even the smallest part is made to exact specifications. ACCUFAB does not use robotics but instead bench grinds and hand polishes each unit to a high luster and in addition each unit is meticulously calibrated. Each and every throttle body is manufactured as if it were going to be used on a racing car so that even if you intend to use your car for only street driving you will still get the sturdier quality and not a lesser quality part.
Tom Meyer 5240 SS Stock ??? Last edited by Tom Meyer; 03-07-2021 at 01:00 PM. |
#122 |
And yet you can apparently change the original boosters in your 735 Holley for "down-leg" boosters and it's OK?
#123 |
Liked 10,822 Times in 2,250 Posts
#124 |
Liked 1,349 Times in 412 Posts
Just one heads up race in stock second round.
#125 |
Liked 67 Times in 28 Posts
#126 |
Liked 83 Times in 20 Posts
Summers was DQ at the sports nationals for having the same carburetor issues. This was a couple of years ago.
John Duzac D/S 4448 STK |
#128 |
Liked 491 Times in 229 Posts
Hows it going Larry ?
Jake Biermann |
#129 |
Liked 586 Times in 162 Posts
#130 |
Haven't seen anything new on DRC
Jake Biermann |
