Old 03-18-2021, 09:41 AM   #1
Joe Marcinowski
Joe Marcinowski's Avatar
Liked 33 Times in 15 Posts
Default Cam I.D. help needed
Anyone know the specs of the following cam? It's an older SBC Super Stock cam.
Comp Cams 4484/312-8 R6
Grind number R 7305
Comp was no help. Thanks in advance.
Joe Marcinowski 3377 STK
Joe Marcinowski is online now   Reply With Quote
Old 03-18-2021, 10:11 AM   #2
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
Default Re: Cam I.D. help needed
Don't know what you are looking for. This is from an older Comp Cams Master List I have.
Stan
Old 03-18-2021, 10:19 AM   #3
pmrphil
Liked 348 Times in 152 Posts
Stan had the intake correct, high ratio, high RPM Super stock, using 1.8 - 2.0 rocker.
The 312-8 is a High torque .440 lobe, 312 adv., 284 @.050, 1.5 through 1.7 rocker ratio.
And you probably know it was ground on a 106 lobe separation.
Phil
Phil Molski
PMR Performance
S/C 1623
Old 03-18-2021, 10:43 AM   #4
Stan Weiss
Stan Weiss's Avatar
OK here is what is listed the exhaust lobe.
Stan
Old 03-18-2021, 12:33 PM   #5
Joe Marcinowski
Stan and Phil...thank you!
Any thoughts on a lash setting?
Old 03-18-2021, 01:02 PM   #6
Stan Weiss
Stan Weiss's Avatar
No, I don't have any idea on lash settings. But remember lash will depend / change based on what rocker arm ratio you are using.
Stan
PS - I found this. It might be a good starting point
Old 03-18-2021, 01:42 PM   #7
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
I went through the Master Lobe Catalogue and came up with the same as Stan The side bar mentions .020. Try that. My 302 Ford with a Crane 448511 cam.254/262 with .599 lift lashes at .020 hot. Sounds like my stick is a lot like yours. Just Blue
Dale Shearon
68 Mustang 6394
Old 03-18-2021, 02:02 PM   #8
outlaw
outlaw's Avatar
Liked 132 Times in 52 Posts
What should lash change be when changing ratios? Say .020 with 1.6 then change to 1.7's what change in lash?
Terry
outlaw is offline   Reply With Quote
Old 03-18-2021, 02:08 PM   #9
Stan Weiss
Stan Weiss's Avatar
Terry
The valve lash * new rocker arm ratio / old rocker arm ratio.
► .020" * 1.7 / 1.6 = 0.02125"
Stan
Old 03-18-2021, 04:13 PM   #10
FireSale
FireSale's Avatar
Wallace Racing has a calculator for lash change with rocker change.
http://www.wallaceracing.com/calc-lash.php
Dale Shearon
68 Mustang 6394
